Окна в панели задач вкл./выкл. (программно)
Попробовал использовать для этого дела (вкл./выкл.) Хелп по Application.SetOption - ох и ругани было (Use Taskbar For Each Document) Пришлось посмотреть, как это делается в Ёкселе. Представьте себе - прокатило! (ShowWindowsInTaskbar) ... |
| 07.04.2003, 13:13 |
из справки Set Options from Visual Basic See Also Specifics You can use the SetOption and GetOption methods to set and return option values in the Options dialog box from code. To view the Options dialog box, click Options on the Tools menu. The following tables list the names of all options that can be set or returned from code and the tabs on which they can be found in the Options dialog box, followed by the corresponding string argument that you must pass to the SetOption or GetOption method. Notes If your database may run on a version of Microsoft Access for a language other than the one in which you created it, then you must supply the arguments for the GetOption and SetOption methods in English. Some options are available only within a Microsoft Access database (.mdb) or Access project (.adp). View Tab Option text String argument Show Status bar \Show Status Bar Show Startup Task Pane \Show Startup Dialog Box Show New object shortcuts \Show New Object Shortcuts Show Hidden objects \Show Hidden Objects Show System objects \Show System Objects Show Windows in Taskbar \ShowWindowsInTaskbar Show in Macro Design, Names column \Show Macro Names Column Show in Macro Design, Conditions column \Show Conditions Column Click options in database window \Database Explorer Click Behavior ... |
| 07.04.2003, 14:03 |
2 ДиД: Да у нас, похоже, Хелпы разные Option text String argument Show Status bar \ Show Status Bar Startup dialog box \ Show Startup Dialog Box New object shortcuts \ Show New Object Shortcuts Hidden objects \ Show Hidden Objects System objects \ Show System Objects Use taskbar for each document \ Use Taskbar For Each Document Show in macro design Names column \ Show Macro Names Column Conditions column \ Show Conditions Column ... |
| 07.04.2003, 17:08 |
start [/forum/search_topic.php?author=DSN%2C&author_mode=last_posts&do_search=1]: |
167ms |
50ms |
| others: | 481ms |
| total: | 776ms |
