Как в программе перехватить (и настроить) запуск БД
То бишь, не в меню НАстройка настраивать параметры запуска, а в VBA? ... |
| 07.06.2003, 15:24 |
Это никто не знает, или отвечать лениво? :)) ... |
| 07.06.2003, 15:43 |
Public Function SetStartProperties() Dim Prop As DAO.Property Dim strAppName As String Dim iErr As Integer Dim stIcon As String On Error GoTo HandleErr ChangeProperty "StartupForm", DB_Text, "AfrmFirst" ChangeProperty "StartupMenuBar", DB_Text, "Главное меню" ChangeProperty "StartupShowDBWindow", DB_Boolean, False ChangeProperty "StartupShowStatusBar", DB_Boolean, True ChangeProperty "AllowBuiltinToolbars", DB_Boolean, False ChangeProperty "AllowFullMenus", DB_Boolean, False ChangeProperty "AllowBreakIntoCode", DB_Boolean, False ChangeProperty "AllowSpecialKeys", DB_Boolean, False ChangeProperty "AllowBypassKey", DB_Boolean, False iErr = 1 APP_NAME: DBEngine(0)(0).Properties("AppTitle") = strAppName Application.RefreshTitleBar iErr = 2 APP_ICON: DBEngine(0)(0).Properties("AppIcon") = stIcon Application.RefreshTitleBar ExitHere: Exit Function HandleErr: Select Case Err.number Case 3270 Select Case iErr Case 1 Set Prop = DBEngine(0)(0).CreateProperty("AppTitle", dbText, " ") DBEngine(0)(0).Properties.Append Prop Resume APP_NAME Case 2 Set Prop = DBEngine(0)(0).CreateProperty("AppIcon", dbText, " ") DBEngine(0)(0).Properties.Append Prop Resume APP_ICON End Select Case Else MsgBox "Îøèáêà #" & Err.number & ": " & Err.Description, vbCritical, "SetStartProperties" End Select Call RecordError(Err.number, Err.Description, "Êëèåíò ÍÒ", "SetStartProperties") End Function Public Function SetApplicationOptions() On Error Resume Next With Application .SetOption "Show Status Bar", False .SetOption "Show Startup dialog box", False .SetOption "Show New object shortcuts", False .SetOption "Left Margin", 0.5 .SetOption "Right Margin", 0.5 .SetOption "Top Margin", 1 .SetOption "Bottom Margin", 1 .SetOption "Provide Feedback with sound", True .SetOption "Track name AutoCorrect info", False .SetOption "Perform name AutoCorrect", False .SetOption "Log name AutoCorrect changes", False .SetOption "Default find/replace behavior", 1 .SetOption "Confirm Record changes", False .SetOption "Confirm Document deletions", False .SetOption "Confirm Action Queries", False .SetOption "Show Values Limit", 1000 .SetOption "Move after enter", False .SetOption "Behavior entering field", 0 .SetOption "Arrow Key Behavior", 0 .SetOption "Cursor Stops At First/Last Field", True .SetOption "Enable DDE Refresh", True .SetOption "Refresh Interval (Sec)", 60 .SetOption "Default Open Mode for Databases", 1 .SetOption "Default Record Locking", 2 .SetOption "Use Row Level Locking", True End With End Function ... |
| 07.06.2003, 17:06 |
Есть мнение, что вместо DbEngine(0)(0) лучше писать CurrentDb. ... |
| 07.06.2003, 18:42 |
Наверное я плохо объясняю :(( Вот ОТКУДА вызывать эти функции? ... |
| 07.06.2003, 20:34 |
Если я правильно разбираюсь в апельсинах, как минимум некоторые из этих настроек считываются (и начинают действовать) прежде, чем что бы то ни было начинает исполняться. ... |
| 07.06.2003, 22:39 |
start [/forum/topic.php?desktop=1&fid=45&tid=1681189]: |
188ms |
44ms |
| others: | 232ms |
| total: | 514ms |
