Pokazath v Otchote tolka zapolnenije polja
Kak mozna zdelath tak shtobi v otchote pokazivalis tolka te polja i podchinjonije otchota v katorih jesth danije a poustije polja ostanutsa nevidimimi? ... |
| 24.07.2003, 10:01 |
Private Sub ОбластьДанных_Format(Cancel As Integer, FormatCount As Integer) If {ТутУсловиеПолеПоказатьЕслиЕстьДанные} Then Me![Поле].Visible = True Else Me![Поле].Visible = False End If End Sub ... |
| 24.07.2003, 11:23 |
Вместо If XXX Then YYY = True Else YYY = False End If проще YYY = XXX ... |
| 24.07.2003, 13:40 |
Gde v pole otchota eta vvoditsa? Veth v jarlike Events netu neodnovo polja ... |
| 12.08.2003, 14:04 |
V chom prichina shto tak i tak vsjo pokazivajetsa. Option Explicit Option Compare Database Private Sub pdTelefons() If (Me.pdTelefons Is Null) Then Me![pdTelefons].Visible = False Else Me![pdTelefons].Visible = True End If End Sub Private Sub pdTelefonsLabel() If (Me.pdTelefons Is Null) Then Me![pdTelefons_Label].Visible = False Else Me![pdTelefons_Label].Visible = True End If End Sub ... |
| 12.08.2003, 15:17 |
start [/forum/topic.php?desktop=1&fid=45&tid=1679957]: |
67ms |
46ms |
| others: | 227ms |
| total: | 392ms |
