Помогите с процедуркой!
Здравствуйте! У меня не выполняется ХП в форме: Access пишет ошибку : Too many arguments were supplied for procedure proba. CREATE PROCEDURE [proba] @InputDate smalldatetime = null, @Value real = null as SET NOCOUNT ON DECLARE @Status int SELECT @Status = 4 RETURN @Status GO По событию нажатия кнопки: Call Record_Value(Me.fld_date.Value, Me.fld_value_manual.Value) Public Sub Record_Value(ByVal InputDate As String, ByVal Value As Double) On Error GoTo Form_Open_Err Dim cmd As ADODB.Command Dim conn As ADODB.Connection Dim Prm As ADODB.Parameter Dim Prm1 As ADODB.Parameter Dim Prm2 As ADODB.Parameter Set conn = CurrentProject.Connection Set cmd = New ADODB.Command With cmd .ActiveConnection = conn .CommandText = "proba" .CommandType = adCmdStoredProc End With Set Prm1 = cmd.CreateParameter(InputDate, adDate, adParamInput, , InputDate) cmd.Parameters.Append Prm1 Set Prm2 = cmd.CreateParameter(Value, adDouble, adParamInput, , Value) cmd.Parameters.Append Prm2 Set Prm = cmd.CreateParameter("Status", adInteger, adParamReturnValue) cmd.Parameters.Append Prm cmd.Execute Status = cmd.Parameters("Status") ' MsgBox str(Status) conn.Close Set conn = Nothing Set cmd = Nothing Form_Open_Exit: Exit Sub Form_Open_Err: MsgBox "Error # " & str(Err.Number) & " was generated by " _ & Err.Source & Chr(13) & Err.Description Resume Form_Open_Exit End Sub ... |
| 03.12.2003, 09:38 |
Заранее благодарен за помощь! ... |
| 03.12.2003, 09:39 |
"Status" не объявлен как выходной (да и вообще как) параметер ... |
| 03.12.2003, 09:43 |
start [/forum/topic.php?desktop=1&fid=45&tid=1677883]: |
154ms |
53ms |
| others: | 221ms |
| total: | 481ms |
