Параметр запуска access определенной формы/отчета
сабж возможен? т.е параметр при запуске xxx.mde выводящий отчет взависимости от параметра ... |
| 02.08.2004, 11:49:23 |
Где-то было, где-то было.... ... |
| 02.08.2004, 11:51:44 |
кажется его зовут /cmd ... |
| 02.08.2004, 11:52:20 |
/topic/80786&hl=%ef%e0%f0%e0%ec%e5%f2%f0+%ea%ee%ec%e0%ed%e4%ed%ee%e9+%f1%f2%f0%ee%ea%e8 Ага, именно так его и зовут.... ... |
| 02.08.2004, 11:52:57 |
вот кусок из хелпа Command Function See Also Specifics You can use the Command function to return the argument portion of the command line used to launch Microsoft Access. Remarks When Microsoft Access is launched from the command line, any portion of the command line that follows the /cmd option is passed to the program as the command-line argument. You can use the Command function to return the argument that has been passed. To change a command-line argument once a database has been opened, click Options on the Tools menu. On the Advanced tab of the Options dialog box, enter a new argument in the Command Line Arguments box. The Command function will now return the new argument you have entered. When the Command function is used anywhere other than in Visual Basic code in a module, you must include empty parentheses after the function. For example, to use the Command function in a text box on a form, you would set the ControlSource property of the text box to an expression like the following: =Command() Example The following example shows how to launch Microsoft Access with a command-line argument, and then shows how to return the value of this argument by using the Command function. To test this example, click the Windows Start button and click Run. Type the following code in the Run dialog box on a single line. (You must surround the parts of the command line information in quotation marks). "C:\Program Files\Microsoft Office\Office10\Msaccess.exe" _ "C:\Program Files\Microsoft Office\Office10\Samples\Northwind.mdb" /cmd "Orders" Next, create a new module in the Northwind sample database and add the following Sub procedure: Public Sub CheckCommandLine() ' Check the value returned by Command function and display ' the appropriate form. If Command = "Orders" Then DoCmd.OpenForm "Orders" ElseIf Command = "Employees" Then DoCmd.OpenForm "Employees" Else Exit Sub End If End Sub When you call this procedure, Microsoft Access will open the Orders form. You can create an AutoExec macro to call this procedure automatically when the database is opened. ... |
| 02.08.2004, 11:57:10 |
класно! "C:\Program Files\Microsoft Office\Office10\MSACCESS.EXE" "C:ххх.mdb" /cmd "ура!" If Command = "ddd" Then MsgBox "работает!" Else MsgBox "хрен!" End If ура! работает! ... |
| 02.08.2004, 12:16:09 |
start [/forum/topic.php?desktop=1&fid=45&tid=1672784]: |
54ms |
34ms |
| others: | 196ms |
| total: | 322ms |
