Список таблиц дрогой базы
Как построить подскажите... ... |
| 18.08.2004, 13:58:29 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. ... |
| 18.08.2004, 14:04:28 |
Спасибо А если база с апролем Куда пароль совать? Set db = OpenDatabase("C:\MyDocs\ACCESS\bank.mdb") ... |
| 18.08.2004, 14:08:07 |
VwСпасибо А если база с апролем Куда пароль совать? Set db = OpenDatabase("C:\MyDocs\ACCESS\bank.mdb") Set db = OpenDatabase("C:\MyDocs\ACCESS\bank.mdb", True, False, ";pwd=pass") Help: You must supply the options and read-only arguments to supply a source string. ... |
| 18.08.2004, 14:16:57 |
Спасибочки.. ... |
| 18.08.2004, 14:19:26 |
смотри хелп по OpenDatabase Help Set database = workspace.OpenDatabase (dbname, options, read-only, connect) The OpenDatabase method syntax has these parts. Part Description database An object variable that represents the Database object that you want to open. workspace Optional. An object variable that represents the existing Workspace object that will contain the database. If you don't include a value for workspace, OpenDatabase uses the default workspace. dbname A String that is the name of an existing Microsoft Jet database file, or the data source name (DSN) of an ODBC data source. See the Name property for more information about setting this value. options Optional. A Variant that sets various options for the database, as specified in Settings. read-only Optional. A Variant (Boolean subtype) value that is True if you want to open the database with read-only access, or False (default) if you want to open the database with read/write access. connect Optional. A Variant (String subtype) that specifies various connection information, including passwords. ... |
| 18.08.2004, 14:20:51 |
А как ещё можно определить системная таблица или нет по приставке Msys или через Код: plaintext 1. 2. 3. 4. 5. я правильно понимаю что у системных объектов tblLink.Attributes<>0 а обычные tblLink.Attributes=0 ... |
| 18.08.2004, 14:25:32 |
start [/forum/topic.php?desktop=1&fid=45&tid=1672375]: |
42ms |
33ms |
| others: | 215ms |
| total: | 325ms |
