DbxoODBC 3.015 - Kylix/Delphi Open Source dbExpress driver
==============================================================* Newsgroup: borland.public.delphi.thirdpartytools.general * From: "Vadim V.Lopushansky" <vadim@unknown.net> * Date: Fri, 18 Jun 2004 18:07:49 +0300 * To: All * Subj: ANN: DbxoODBC 3.015 - Kylix/Delphi Open Source dbExpress driver ============================================================== Dear Developers, I am glad to announce the newest "dbxoodbc" release 3.0.1.5, which fixed the reported bugs. "dbxoodbc" is Kylix/Delphi open source DbExpress driver for ODBC or Direct ODBC (without odbc manager). WhatNews: Added supports odbc 2.0 for odbc direct mode. Now "dbxoodbc" supports directly mode the following odbc drivers: - IBM DB2 Universal Database Client Library. - Informix Server CLI Library. - Interbase/Firebird/Yafill odbc drivers: Phoenix, Easysoft, Gemini, XTG. - Oracle odbc drivers. - Microsoft SQL Server odbc driver. - MySQL odbc driver. - PostgreSQL odbc driver. - MSJet odbc driver (Access, dBase, Paradox, Excel, CVS). - Merant DBase, Clipper, Foxpro odbc driver. - Gupta odbc driver. - PostgreSQL odbc driver. - Cache` odbc driver. - Sybase odbc driver. - ThinkSQL odbc driver. - PervasizeSQL odbc driver. - ThinkSQL odbc driver. - also ODBC datasources. Home page: http://open-dbexpress.sourceforge.net/ SourceForge Project Home Page: https://sourceforge.net/projects/open-dbexpress/ First, you must test with the latest version from the CVS area: Project Sources: I recommend Tortoise CVS as the easiest to use Windows CVS client, from http://www.tortoisecvs.org You will need to enter the CVS path (all on one line, including the leading colon: :pserver:anonymous@cvs.open-dbexpress.sourceforge.net:/cvsroot/open-dbexpres s or Example of loading/updating of the project from CVS by means of a batch file. For work it is necessary to edit a path to cvs.exe. load_cvs_dbxoodbc.bat ==============================================================@echo off set path=C:\Program Files\GNU\WinCvs 1.3\CVSNT;%path% rem set path=D:\CygWin\bin;%path% echo ********************************************** echo - When prompted for a password for anonymous, echo simply press the Enter key. echo ********************************************** set cvsproj=cvs-pserver.sourceforge.net:80/cvsroot/open-dbexpress echo on cvs -d:pserver:anonymous@%cvsproj% login cvs -z3 -d:pserver:anonymous@%cvsproj% co dbxoodbc ============================================================== ... |
| 18.06.2004, 20:45 |
start [/forum/topic.php?desktop=1&fid=44&tid=1609249]: |
70ms |
40ms |
| others: | 252ms |
| total: | 416ms |
