почему IDS решил добавить виртуальные сегменты
IDS 9.21 Linux 7.3 Ситуация такая Упал Informix видимо из-за проблем со SCSI Sep 23 21:11:44 tproliant1 kernel: scsi : aborting command due to timeout : pid 395156202, scsi0, ch annel 0, id 2, lun 2 Write (10) 40 01 9e a4 48 00 03 f8 00 Sep 23 21:11:44 tproliant1 kernel: sym53c8xx_abort: pid=395156202 serial_number=395155344 serial_num ber_at_timeout=395155344 Sep 23 21:11:44 tproliant1 kernel: sym53c896-0-<2,*>: control msgout: 82 20 1f d. Sep 23 21:11:44 tproliant1 kernel: SCSI disk error : host 0 channel 0 id 2 lun 2 return code = 25050 07f Sep 23 21:11:44 tproliant1 kernel: I/O error: dev 08:1d, sector 559136 Sep 23 21:11:44 tproliant1 kernel: SCSI disk error : host 0 channel 0 id 2 lun 2 return code = 25050 07f Sep 23 21:11:44 tproliant1 kernel: I/O error: dev 08:17, sector 320191 Sep 23 21:11:44 tproliant1 kernel: SCSI disk error : host 0 channel 0 id 2 lun 2 return code = 25050 07f Sep 23 21:11:44 tproliant1 kernel: I/O error: dev 08:17, sector 320064 Sep 23 21:11:44 tproliant1 kernel: SCSI disk error : host 0 channel 0 id 2 lun 2 return code = 25050 07f Sep 23 21:11:44 tproliant1 kernel: I/O error: dev 08:16, sector 229036 Sep 23 21:11:44 tproliant1 kernel: SCSI disk error : host 0 channel 0 id 2 lun 2 return code = 25050 07f Sep 23 21:11:44 tproliant1 kernel: I/O error: dev 08:1b, sector 2051384 Sep 23 21:11:44 tproliant1 kernel: sym53c896-0:2: message d sent on bad reselection. Sep 23 21:19:21 tproliant1 shutdown: shutting down for system reboot Sep 23 21:19:22 tproliant1 init: Switching to runlevel: 6 После временного устранения INformix перестал загружаться: 21:15:02 Event alarms enabled. ALARMPROG = '/usr/informix/etc/log_full.sh' 21:15:03 Booting Language <c> from module <> 21:15:03 Loading Module <CNULL> 21:15:03 Booting Language <builtin> from module <> 21:15:03 Loading Module <BUILTINNULL> 21:15:10 Informix Dynamic Server 2000 Version 9.21.UC3 Software Serial Number AAC#J892900 21:15:10 Informix Dynamic Server 2000 Initialized -- Shared Memory Initialized. 21:15:10 Physical Recovery Started. 21:15:12 Physical Recovery Complete: 362 Pages Restored. 21:15:12 Logical Recovery Started. 21:15:12 10 recovery worker threads will be started. 21:15:13 Fast Recovery Switching to Log 124322 21:15:13 Fast Recovery Switching to Log 124323 21:15:14 Fast Recovery Switching to Log 124324 21:15:14 Fast Recovery Switching to Log 124325 21:15:16 Logical Recovery Complete. 10911 Committed, 0 Rolled Back, 0 Open, 0 Bad Locks 21:15:17 Dataskip is now OFF for all dbspaces 21:15:18 Checkpoint Completed: duration was 0 seconds. 21:15:18 Checkpoint loguniq 124325, logpos 0xce018 21:15:18 Dropping temporary TBLspace 100060, recovering 8 pages. 21:15:18 Dropping temporary TBLspace 100061, recovering 8 pages. 21:15:18 Dropping temporary TBLspace 100062, recovering 8 pages. 21:15:18 Dropping temporary TBLspace 100063, recovering 8 pages. 21:15:18 Dropping temporary TBLspace 100064, recovering 8 pages. 21:15:18 Dropping temporary TBLspace 100065, recovering 8 pages. 21:15:18 Dropping temporary TBLspace 100066, recovering 8 pages. 21:15:18 Dropping temporary TBLspace 100067, recovering 8 pages. 21:15:18 On-Line Mode 21:15:18 Informix Dynamic Server 2000 Stopped. 21:28:01 Informix Dynamic Server 2000 Started. 21:28:03 Segment locked: addr=0x10000000, size=418852864 Fri Sep 23 21:28:04 2005 21:28:04 Event alarms enabled. ALARMPROG = '/usr/informix/etc/log_full.sh' 21:28:04 Booting Language <c> from module <> 21:28:04 Loading Module <CNULL> 21:28:04 Booting Language <builtin> from module <> 21:28:04 Loading Module <BUILTINNULL> 21:28:12 Informix Dynamic Server 2000 Version 9.21.UC3 Software Serial Number AAC#J89290 21:28:12 Informix Dynamic Server 2000 Initialized -- Shared Memory Initialized. 21:28:12 Physical Recovery Started. 21:28:12 Physical Recovery Complete: 0 Pages Restored. 21:28:12 Logical Recovery Started. 21:28:12 10 recovery worker threads will be started. 21:28:12 Size of resident + virtual segments 409036KB + 934148KB > 972800KB 21:28:12 total allowed by configuration parameter SHMTOTAL 21:28:12 out of virtual shared memory 21:29:17 Cannot Rollforward from Checkpoint. 21:29:18 Informix Dynamic Server 2000 Stopped. 21:29:19 mt_shm_remove: WARNING: may not have removed all/correct segments 21:29:52 Informix Dynamic Server 2000 Started. 21:29:54 Segment locked: addr=0x10000000, size=418852864 ----- SHMTOTAL поменял на 0 (Unlimited) IDS запустился , но добавил 4 виртуальных сегмента ------ Shared Memory Segments -------- key shmid owner perms bytes nattch status 0x52564801 229377 root 660 418852864 29 locked 0x52564802 262146 root 660 131072000 29 0x52564803 294915 root 660 268435456 29 0x52564804 327684 root 660 268435456 29 0x52564805 360453 root 660 268435456 29 0x52564806 393222 root 660 20189184 29 почему IDS решил добавить виртуальные сегменты? Segment Summary: id key addr size ovhd class blkused blkfree 229377 1381386241 10000000 418852864 227552 R* 102232 27 262146 1381386242 28f73000 131072000 4600 V 7349 24651 294915 1381386243 42135000 825495552 25800 V 7 201530 Total: - - 1375420416 - - 109588 226208 ... |
| 25.09.2005, 07:50 |
потому что вы 1. меняли параметры shared memory перед падением и не перегружали сервер после внесения изменений. 2. и меняли их так, что информиксу потребовалось больше памяти, чем вы выделили в SHMTOTAL 3. а SHMADD выставлен слишком маленьким, поэтому чтобы набрать всю необходимую память информиксу пришлось выделять четыре куска. Хотелось бы увидеть конфиг файл. Кстати, судя по вашему логу, Информикс поднялся нормально и был остановлен - 21:15:18 On-Line Mode 21:15:18 Informix Dynamic Server 2000 Stopped. ... |
| 26.09.2005, 21:03 |
Клянусь, со значением SHMTOTAL = 972800, IDS перегружался много раз. Вчера перезапустил IDS еще раз. Стало как раньше: ------ Shared Memory Segments -------- key shmid owner perms bytes nattch status 0x52564801 32769 root 660 418852864 29 locked 0x52564802 65538 root 660 131072000 29 Может от проблем со SCSI информикс кешировал информацию в логах, а при запуске - пытался ее выгрузить в shared memory? ... |
| 27.09.2005, 11:12 |
насчет "кешировать информацию" я не понял, но если вы параметры не меняли, значит logical recovery потребовало себе слишком много памяти, в результате чего общий размер памяти превысил выставленный барьер. После второго перезапуска восстановление уже не понадобилось, таким образом память вернулась к прежним размерам. ... |
| 27.09.2005, 21:13 |
Кстати, это говорит о том, что ограничение на размер памяти у вас выставлено очень низко, если logical recovery может выбить вас за пределы. ... |
| 27.09.2005, 21:15 |
Вообще-то очень странный лог. Все восстановление, и физическое и логическое, прошло нормально. Сервер был остановлен (?). После чего заново запущен - и логическое восстановление зачем-то потребовало себе много памяти, вылезло за пределы уже выделенных сегментов, SHMADD около 800K, общий объем больше разрешенного, дальше понятно. Вопрос - какая операция в logical log 124325, за logpos 0xce018 потребовала такой объем памяти ? Что говорит onlog -n 124325 ? И зря вы обрезали вывод лога, интересно посмотреть на количество Committed, Rolled Back, Open, и Bad Locks ... |
| 27.09.2005, 21:32 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608899]: |
27ms |
48ms |
| others: | 203ms |
| total: | 325ms |
