Internal Communications Error: NSF subsystem error.
Собственно сабж. Сервер не поднимается. Выдает ошибку: -------------------------------------------------------- 18:13:10 Informix Dynamic Server 2000 Started. Tue Jan 10 18:13:10 2006 18:13:10 Event alarms enabled. ALARMPROG = '/opt/informix/etc/log_full.sh' 18:13:11 Booting Language <c> from module <> 18:13:11 Loading Module <CNULL> 18:13:11 Booting Language <builtin> from module <> 18:13:11 Loading Module <BUILTINNULL> 18:13:16 listener-thread: err = -27100: oserr = 9: errstr = : Internal Communic ations Error: NSF subsystem error. System error = 9. 18:13:16 Attempting to bring listener thread down. 18:13:16 Server stopped. -------------------------------------------------------- из onconfig -------------------------------------------------------- # System Configuration SERVERNUM 1 # Unique id corresponding to a OnLine instance DBSERVERNAME isdn_sw # Name of default database server DBSERVERALIASES # List of alternate dbservernames #DBSERVERALIASES isdn_sw_shm # List of alternate dbservernames NETTYPE soctcp,1,100,NET # Configure poll thread(s) for nettype NETTYPE ipcshm,1,100,CPU # Configure poll thread(s) for nettype DEADLOCK_TIMEOUT 60 # Max time to wait of lock in distributed env. RESIDENT 0 # Forced residency flag (Yes = 1, No = 0) MULTIPROCESSOR 0 # 0 for single-processor, 1 for multi-processor NUMCPUVPS 1 # Number of user (cpu) vps SINGLE_CPU_VP 0 # If non-zero, limit number of cpu vps to one NOAGE 0 # Process aging AFF_SPROC 0 # Affinity start processor AFF_NPROCS 0 # Affinity number of processors -------------------------------------------------------- sqlhosts: -------------------------------------------------------- isdn_sw onsoctcp 192.168.200.3 1425 -------------------------------------------------------- есть ли шансы его поднять? что посоветуете? ... |
| 11.01.2006, 14:51 |
Да, все это хозяйтсво на Linux, Informix Dynamic Server 2000 Version 9.21.UC4 ... |
| 11.01.2006, 14:53 |
Linux 2.4.7-10 ... |
| 11.01.2006, 14:54 |
Закоментируйте строчку Код: plaintext 1. Но могут быть проблемы с соединениями через shared memory. У вас когда то это было сконфигурено, может быть в другой жизни :). ... |
| 11.01.2006, 15:47 |
onstat-Закоментируйте строчку Код: plaintext 1. Но могут быть проблемы с соединениями через shared memory. У вас когда то это было сконфигурено, может быть в другой жизни :). Да там большая половина из прошлой жизни. поменяла onconfig DBSERVERALIASES isdn_sw_shm # List of alternate dbservernames в sqlhosts isdn_sw_shm onipcshm localhost ifx_shm но результат тот же. ... |
| 11.01.2006, 16:32 |
1. Попробуйте запустить oninit -v По выводу можно определть немного больше, чем по логу. 2. Просмотрите память и семафоры - ipcs. Лишнее можно удалить. 3. Перед запуском очистите каталог /INFORMIXTMP/ 4. Не занят ли порт случайно чем-то другим? ... |
| 11.01.2006, 17:30 |
ladyirina onstat-Закоментируйте строчку Код: plaintext 1. Но могут быть проблемы с соединениями через shared memory. У вас когда то это было сконфигурено, может быть в другой жизни :). Да там большая половина из прошлой жизни. поменяла onconfig DBSERVERALIASES isdn_sw_shm # List of alternate dbservernames в sqlhosts isdn_sw_shm onipcshm localhost ifx_shm но результат тот же. Для каждого DBSERBVER{NAME|ALIASES} должен быть свой NETTYPE и соответствующая запись в sqlhosts и ничего лишнего. ... |
| 11.01.2006, 17:41 |
oninit -v Checking group membership to determine server run modesucceeded Reading configuration file '/opt/informix/etc/onconfig'...succeeded Creating /INFORMIXTMP/.infxdirs ... succeeded Creating infos file "/opt/informix/etc/.infos.isdn_sw" ... "/opt/informix/etc/.conf.isdn_sw" ... succeeded Writing to infos file ... succeeded Checking config parameters...succeeded Allocating and attaching to shared memory...succeeded Creating resident pool 566 kbytes...succeeded Creating buffer pool 2002 kbytes...succeeded Initializing rhead structure...succeeded Initializing ASF ...succeeded Initializing Dictionary Cache and SPL Routine Cache...succeeded Bringing up ADM VP...succeeded Creating VP classes...succeeded Onlining 0 additional cpu vps...succeeded Onlining 2 IO vps...succeeded Forking main_loop thread...succeeded Initializing DR structures...succeeded Forking 1 'soctcp' listener threads... порт ничем другим не занят. в /etc/services не встречается упоминания о 1425, во всяком случае. ... |
| 11.01.2006, 17:42 |
onstat- Для каждого DBSERBVER{NAME|ALIASES} должен быть свой NETTYPE и соответствующая запись в sqlhosts и ничего лишнего. сейчас в onconfig DBSERVERNAME isdn_sw # Name of default database server DBSERVERALIASES isdn_sw_shm # List of alternate dbservernames NETTYPE soctcp,1,100,NET # Configure poll thread(s) for nettype NETTYPE ipcshm,1,100,CPU # Configure poll thread(s) for nettype sqlhost: isdn_sw onsoctcp 192.168.200.3 1425 isdn_sw_shm onipcshm localhost ifx_shm ... |
| 11.01.2006, 17:46 |
z 2. Просмотрите память и семафоры - ipcs. Лишнее можно удалить. как именно? z 3. Перед запуском очистите каталог /INFORMIXTMP/ можно просто удалить там все? ... |
| 11.01.2006, 17:47 |
z 3. Перед запуском очистите каталог /INFORMIXTMP/ ls -al /INFORMIXTMP/ total 12 -rw-rw-r-- 1 root informix 14 Feb 10 2005 .infxdirs srwxrwx--- 1 root informix 0 Oct 5 13:50 VP.isdn_sw.0101s это все можно ручками удалить? ... |
| 11.01.2006, 17:49 |
ipcs ------ Shared Memory Segments -------- key shmid owner perms bytes nattch status ------ Semaphore Arrays -------- key semid owner perms nsems status ------ Message Queues -------- key msqid owner perms used-bytes messages ... |
| 11.01.2006, 17:53 |
ladyirinaСобственно сабж. Сервер не поднимается. Выдает ошибку: -------------------------------------------------------- 18:13:10 Informix Dynamic Server 2000 Started. Tue Jan 10 18:13:10 2006 ... есть ли шансы его поднять? что посоветуете? Если сервер до этого нормально работал, то я бы посоветовал сначала внимательно проанализировать - что изменилось в системе в последнее время. Особенно в период после предыдущей перезагрузки и до вчера 18:00. Под системой понимается как настройка IDS, так и Линукса, сетевое окружение и железо в сети. Под "внимательно проанализировать" имеется ввиду хорошо потрясти всех людей, которые могли иметь к этому отношение, а также проверить работоспособность сети на самом компе. ... |
| 11.01.2006, 18:17 |
ladyirinaCreating resident pool 566 kbytes...succeeded Creating buffer pool 2002 kbytes...succeeded Судя по почти дефолтовым параметрам сервер тестовый , поэтому рекомендовал бы сильно не париться, а заново все поставить. ... |
| 11.01.2006, 18:20 |
ladyirina sqlhost: isdn_sw onsoctcp 192.168.200.3 1425 isdn_sw_shm onipcshm localhost ifx_shm Что такое ifx_shm ? по моему там дожно быть "on_servername" и результат egrep 'local|192.168.3.200' /etc/hosts; grep 1425 /etc/services; в студию. ... |
| 11.01.2006, 18:44 |
vasilis Если сервер до этого нормально работал, то я бы посоветовал сначала внимательно проанализировать - что изменилось в системе в последнее время. Особенно в период после предыдущей перезагрузки и до вчера 18:00. Под системой понимается как настройка IDS, так и Линукса, сетевое окружение и железо в сети. Под "внимательно проанализировать" имеется ввиду хорошо потрясти всех людей, которые могли иметь к этому отношение, а также проверить работоспособность сети на самом компе. Утверждают, что ничего не делали, кроме перезагрузки сервера. Возможно, верить никому нельзя :-) На самом компе. Собственно сеть доступна, именно по ней я на него и захожу. Сервер условно тестовый. То есть, конечно, тестовый, но данные в базах настроили под себя. Соответственно переставлять все - это большая работа руками. В том числе и вспоминать, что и кто делал. Если по-другому не удастся - то придется. Пока хочется обойтись без этого. А что вы скажите на счет варианта - созранить чанки, переставить сервер, прописать в дбспейсах по тем же путям те же чанки, и подменить их старыми. Поможет, или при большом геморре вылезут те же проблемы? ... |
| 11.01.2006, 18:50 |
onstat- ladyirina sqlhost: isdn_sw onsoctcp 192.168.200.3 1425 isdn_sw_shm onipcshm localhost ifx_shm Что такое ifx_shm ? по моему там дожно быть "on_servername" и результат egrep 'local|192.168.3.200' /etc/hosts; grep 1425 /etc/services; в студию. А по-моему, именно ifx_shm. Но на 100% утверждать не буду. А что такое "on_servername"? Как говорила в /etc/services нет упоминания о порте 1425. [informix@apple /]$ grep 1425 /etc/services [informix@apple /]$ egrep 'local|192.168.3.200' /etc/hosts 127.0.0.1 apple.ren.ru localhost.localdomain localhost ... |
| 11.01.2006, 18:57 |
vasilis ladyirinaСобственно сабж. Сервер не поднимается. Выдает ошибку: -------------------------------------------------------- 18:13:10 Informix Dynamic Server 2000 Started. Tue Jan 10 18:13:10 2006 ... есть ли шансы его поднять? что посоветуете? Если сервер до этого нормально работал, то я бы посоветовал сначала внимательно проанализировать - что изменилось в системе в последнее время. Особенно в период после предыдущей перезагрузки и до вчера 18:00. Под системой понимается как настройка IDS, так и Линукса, сетевое окружение и железо в сети. Под "внимательно проанализировать" имеется ввиду хорошо потрясти всех людей, которые могли иметь к этому отношение, а также проверить работоспособность сети на самом компе. Если это поможет, хотя не думаю. Что было перед первым появлением этой ошибки: скорее всего нормально его не остановили. потому что выдержка из online.log : 09:05:24 Fuzzy Checkpoint Completed: duration was 0 seconds, 286 buffers not f lushed. 09:05:24 Checkpoint loguniq 19, logpos 0x1589148 10:32:54 Informix Dynamic Server 2000 Started. Thu Dec 15 10:32:54 2005 10:32:54 Event alarms enabled. ALARMPROG = '/opt/informix/etc/log_full.sh' 10:32:54 Booting Language <c> from module <> 10:32:54 Loading Module <CNULL> 10:32:54 Booting Language <builtin> from module <> 10:32:54 Loading Module <BUILTINNULL> 10:33:00 listener-thread: err = -27100: oserr = 9: errstr = : Internal Communic ations Error: NSF subsystem error. System error = 9. 10:33:00 Attempting to bring listener thread down. 10:33:00 Server stopped. ... |
| 11.01.2006, 19:00 |
ladyirina onstat- ladyirina sqlhost: isdn_sw onsoctcp 192.168.200.3 1425 isdn_sw_shm onipcshm localhost ifx_shm Что такое ifx_shm ? по моему там дожно быть "on_servername" и результат egrep 'local|192.168.3.200' /etc/hosts; grep 1425 /etc/services; в студию. А по-моему, именно ifx_shm. Но на 100% утверждать не буду. А что такое "on_servername"? Как говорила в /etc/services нет упоминания о порте 1425. [informix@apple /]$ grep 1425 /etc/services [informix@apple /]$ egrep 'local|192.168.3.200' /etc/hosts 127.0.0.1 apple.ren.ru localhost.localdomain localhost Так Кто же всетаки имеeт адрес 192.168.3.200 ? Если он привязан к какому либо интерфейсу на этом хосте попробуйте его прописать в /etc/hosts ... |
| 11.01.2006, 19:11 |
onstat- Так Кто же всетаки имеeт адрес 192.168.3.200 ? Если он привязан к какому либо интерфейсу на этом хосте попробуйте его прописать в /etc/hosts /etc/hosts уже прописан. 127.0.0.1 apple.ren.ru localhost.localdomain localhost 192.168.200.3 apple.ren.ru apple ... |
| 11.01.2006, 19:21 |
Так адрес оканчивается на 200.3 или 3.200 , Попробуйте закомментарить алиас в onconfig и в sqlhosts и поднять без shared memory connection. Затем - закомментарить shm и поднять только с ip connection. И что такое system error 9 ? что в error.h на эту тему ? Убедитесь, что в /etc/services нет ifx_shm В таком вот аксепте ... |
| 11.01.2006, 20:06 |
Кстати, system error 9 на SunOS - #define EBADF 9 /* Bad file number */ Если у вас падал весь сервер (или информикс был убит), то, возможно, остался поломанный файл ifx_shm. Попробуйте в sqlhosts переименовать 4й параметр для shared mem connection во что-нибудь другое, хоть aaa В таком вот аксепте ... |
| 11.01.2006, 20:19 |
onstat- ladyirina sqlhost: isdn_sw onsoctcp 192.168.200.3 1425 isdn_sw_shm onipcshm localhost ifx_shm Что такое ifx_shm ? по моему там дожно быть "on_servername" Вы оба правы :) Shared-Memory and Stream-Pipe Communication When the nettype field specifies a shared-memory connection (onipcshm) or a stream-pipe connection (onipcstr), the database server uses the value in the servicename entry internally to create a file that supports the connection . For both onipcshm and onipcstr connections, the servicename can be any short group of letters that is unique in the environment of the host computer where the database server resides. It is recommended that you use the dbservername as the servicename for stream-pipe connections. ... |
| 11.01.2006, 21:16 |
ladyirina z 3. Перед запуском очистите каталог /INFORMIXTMP/ ls -al /INFORMIXTMP/ total 12 -rw-rw-r-- 1 root informix 14 Feb 10 2005 .infxdirs srwxrwx--- 1 root informix 0 Oct 5 13:50 VP.isdn_sw.0101s это все можно ручками удалить? Раз сервер не был остановлен нормально, сам он не сумел почистить это каталог. Он запущен был случайно не 5 октября в 13:50? ... |
| 12.01.2006, 09:44 |
ВыбегаллоТак адрес оканчивается на 200.3 или 3.200 , 192.168.200.3 как и прописано в /ets/hosts Выбегалло Попробуйте закомментарить алиас в onconfig и в sqlhosts и поднять без shared memory connection. Затем - закомментарить shm и поднять только с ip connection. И что такое system error 9 ? что в error.h на эту тему ? Убедитесь, что в /etc/services нет ifx_shm В таком вот аксепте # System Configuration комментирую в onconfig-е: SERVERNUM 1 # Unique id corresponding to a OnLine instance DBSERVERNAME isdn_sw # Name of default database server #DBSERVERALIASES isdn_sw_shm # List of alternate dbservernames NETTYPE soctcp,1,100,NET # Configure poll thread(s) for nettype #NETTYPE ipcshm,1,100,CPU # Configure poll thread(s) for nettype DEADLOCK_TIMEOUT 60 # Max time to wait of lock in distributed env. RESIDENT 0 # Forced residency flag (Yes = 1, No = 0) комментирую в sqlhosts: isdn_sw onsoctcp 192.168.200.3 1425 #isdn_sw_shm onipcshm localhost ifx_shm в /etc/services нет ifx_shm. тоже самое имеем в online.log 13:32:25 Informix Dynamic Server 2000 Started. Thu Jan 12 13:32:25 2006 13:32:25 Event alarms enabled. ALARMPROG = '/opt/informix/etc/log_full.sh' 13:32:25 Booting Language <c> from module <> 13:32:25 Loading Module <CNULL> 13:32:25 Booting Language <builtin> from module <> 13:32:25 Loading Module <BUILTINNULL> 13:32:30 listener-thread: err = -27100: oserr = 9: errstr = : Internal Communic ations Error: NSF subsystem error. System error = 9. 13:32:30 Attempting to bring listener thread down. 13:32:30 Server stopped. в /usr/src/linux/include/asm-i386/errno.h #define EBADF 9 /* Bad file number */ ... |
| 12.01.2006, 13:41 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608785]: |
32ms |
32ms |
| others: | 193ms |
| total: | 283ms |
