Проблема на 10-ке с oninit -i
Система - Red Hat Ent/AS 4 - Linux 2.6.9-34.ELsmp #1 SMP Fri Feb 24 16:54:53 EST 2006 i686 i686 i386 GNU/Linux Informix - IBM Informix Dynamic Server Version 10.00.UC4 sqlhosts: cardhold onsoctcp processing sqlexec oncardhold onipcshm processing processing onconfig: SERVERNUM 0 # Unique id corresponding to a OnLine instance DBSERVERNAME oncardhold # Name of default database server DBSERVERALIASES cardhold # List of alternate dbservernames NETTYPE ipcshm,1,5,CPU NETTYPE soctcp,1,20,NET При загрузке системы имя сервера informix экспортится - cardhold Запускаю oninit -viy он выдает: Checking group membership to determine server run mode...succeeded Reading configuration file '/usr/inf.10/etc/onconfig'...succeeded Creating /INFORMIXTMP/.infxdirs...succeeded Creating infos file "/usr/inf.10/etc/.infos.onprocessing"...succeeded Linking conf file "/usr/inf.10/etc/.conf.onprocessing"...succeeded Writing to infos file...succeeded Checking config parameters...succeeded Allocating and attaching to shared memory...succeeded Creating resident pool 1860 kbytes...succeeded Allocating 10016 kbytes for buffer pool of 2K page size...succeeded Initializing rhead structure...succeeded Initializing ASF...succeeded Initializing Dictionary Cache and SPL Routine Cache...succeeded Bringing up ADM VP...succeeded Creating VP classes...succeeded Onlining 1 additional cpu vps...succeeded Onlining 2 IO vps...succeeded Initialization of Encryption...succeeded Forking main_loop thread...succeeded Initializing DR structures...succeeded Forking 1 'ipcshm' listener threads...succeeded Forking 1 'soctcp' listener threads...succeeded Starting tracing...succeeded Initializing 1 flushers...succeeded Initializing log/checkpoint information...succeeded Opening primary chunks...succeeded Opening mirror chunks...succeeded Initializing dbspaces...succeeded Validating chunks...succeeded Creating database partition...succeeded Initialize Async Log Flusher...succeeded Forking btree cleaner...succeeded Initializing DBSPACETEMP list...succeeded Checking database partition index...succeeded Checking location of physical log...succeeded Initializing dataskip structure...succeeded Checking for temporary tables to drop...succeeded Forking onmode_mon thread...succeeded Verbose output complete: mode = 5 В online.log, такая фигня :( Maximum server connections 0 17:46:39 Dataskip is now OFF for all dbspaces 17:46:39 On-Line Mode 17:46:39 Affinitied VP 1 to phys proc 0 17:46:39 Affinitied VP 3 to phys proc 1 17:46:39 Building 'sysmaster' database ... 17:46:52 listener-thread: err = -930: oserr = 0: errstr = processing: Cannot connect to database server (processing). 17:46:52 sql_listener: ASF_LISTEN failed 17:46:52 Attempting to bring listener thread down. 17:46:52 Server stopped. Где он выколупывает это - server (processing). Не могу понять. Кто-то может с таким сталкивался? ... |
| 15.06.2006, 19:12 |
все правильно, в /etc/service он не может найти processing для вашего: oncardhold onipcshm processing processing ... |
| 15.06.2006, 20:42 |
http://groups.google.com/group/comp.databases.informix/browse_frm/thread/75ff9a7bc7cb8a26?tvc=1 1. попробуй поднять с интерфейсом onipcshm , убрав onsoctcp 2. если поднимется - проверь, прописан ли sqlexec в /etc/hosts, работает ли ip адрес и не слушает ли кто еще на этом порту. В таком вот аксепте ... |
| 15.06.2006, 20:44 |
пардон, не в /etc/hosts а в /etc/services, как правильно заметил предыдущий оратор. В таком вот аксепте ... |
| 15.06.2006, 20:45 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608641]: |
68ms |
49ms |
| others: | 242ms |
| total: | 408ms |
