SDK error
Здравствуйте. IDS 7.31.UD8 SDK 2.90.TC3 Регулярно, но очень непредсказуемо вылетает такая ошибка. Error: System.Threading.AbandonedMutexException: The wait completed due to an abandoned mutex. at System.Threading.WaitHandle.WaitOne(Int64 timeout, Boolean exitContext) at System.Threading.WaitHandle.WaitOne(Int32 millisecondsTimeout, Boolean exitContext) at System.Threading.WaitHandle.WaitOne() at IBM.Data.Informix.IfxConnPoolManager.GetPool(IfxConnSettings key) at IBM.Data.Informix.IfxConnPoolManager.Open(IfxConnection connection) at IBM.Data.Informix.IfxConnection.Open() at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, String srcTable) Никто случайно не знает, как с этим бороться? ... |
| 08.11.2006, 12:01 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608553]: |
191ms |
38ms |
| others: | 250ms |
| total: | 523ms |
