Если oncheck начинает сильно тормозить - описание бага...
Свеженький баг, правда, не очень серьезный :) Slow onchecks in 9.40 and 10.0 If you've noticed oncheck taking a long time to complete in IDS 9.40 and 10.0 you could be running into a known problem with missing read aheads. The defect, which has yet to be assigned an external APAR number, has the following description: Код: plaintext This problem is fixed in IDS 9.40.xC8W3 and 10.00.xC5W1 or later. Note: A 'W' release represents a Post Interim Drop or PID containing bug fixes checked into the code line since the last interim release. There are typically 5 PIDs between two interim releases like (for example) UC8 and UC9. ... |
| 01.12.2006, 15:15 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608522]: |
149ms |
36ms |
| others: | 216ms |
| total: | 445ms |
