oncheck говорит об ошибке
Informix ODS 7.31 FD6 SunOS 5.9 вот выдержка из oncheck -pc TBLspace invest98:informix.logreesdoc Physical Address 6800006 Creation date 10/22/2006 19:40:50 TBLspace Flags 902 Row Locking TBLspace contains VARCHARS TBLspace use 4 bit bit-maps Maximum row size 396 Number of special columns 1 Number of keys 6 Number of extents 22 Current serial value 1 First extent size 200000 Next extent size 100000 Number of pages allocated 7450000 Number of pages used 7384795 Number of data pages 6416111 Number of rows 32235129 Partition partnum 16777219 Partition lockid 16777219 Extents Logical Page Physical Page Size 0 683b2df 200000 200000 6803af7 100000 300000 681d17f 100000 400000 686c01f 50000 450000 6885237 500000 950000 6900003 1000000 1950000 6a00003 450000 2400000 6a6e413 50000 2450000 6a7cddb 50000 2500000 6a8a0e3 50000 2550000 6a98a73 50000 2600000 6aa7be3 50000 2650000 6ab55a3 50000 2700000 6ac319b 50000 2750000 6ad0a53 50000 2800000 6aed133 50000 2850000 6b00003 100000 2950000 6b261f3 800000 3750000 6c00003 1000000 4750000 6d00003 1000000 5750000 6e00003 1000000 6750000 6f00003 700000 Index information. Number of indexes 6 Data record size 396 Index record size 2048 Number of records 3.22351e+07 ISAM error: illegal key descriptor (too many parts or too long). TBLspace name logreesdoc Owner informix TBLspace number 1000003 Tabid 8684 Row size 396 Number of columns 38 Number of indexes 6 Number of rows 0 Date created 22.10.2006 TBLspace major version number 8684 TBLspace minor version number 11 TBLspace type T Locking level R Number of pages used 0 First extent size 400000 Next extent size 100000 Flags 0 Site Database name TBLspace invest98:informix.f251rdoc Physical Address f200005 Creation date 03/30/2007 11:18:15 TBLspace Flags 801 Page Locking TBLspace use 4 bit bit-maps Maximum row size 26 Number of special columns 0 Number of keys 4 Number of extents 1 Current serial value 1 First extent size 5000 Next extent size 5000 Number of pages allocated 40000 Number of pages used 37233 Number of data pages 17113 Number of rows 1146562 Partition partnum 23068674 Partition lockid 23068674 Extents Logical Page Physical Page Size 0 f200035 40000 Index information. Number of indexes 4 Data record size 26 Index record size 2048 Number of records 1.14656e+06 ISAM error: illegal key descriptor (too many parts or too long). oncheck -cd на таблицу logreesdoc говорит что все нормально ... |
| 12.04.2007, 11:54 |
cproncheck -cd на таблицу logreesdoc говорит что все нормально а что говорит oncheck -cI? ... |
| 12.04.2007, 12:03 |
для таблицы logreesdoc oncheck -cI пока только для одного индекса по int-овой колонке прогнал, индекс валидный. чекать можно только ночью, т.к. тормозит систему прилично. записей много. может таблицу сразу того ... дропнуть и перезагрузить? вот для второй таблицу f251r валидны данные и индексы , т.е. oncheck cI cD говорит что все нормально ... |
| 12.04.2007, 12:14 |
oncheck -ce и -cr на БД говорит что все нормально ... |
| 12.04.2007, 12:19 |
cprдля таблицы logreesdoc oncheck -cI пока только для одного индекса по int-овой колонке прогнал, индекс валидный. чекать можно только ночью, т.к. тормозит систему прилично. записей много. может таблицу сразу того ... дропнуть и перезагрузить? А зачем, если можно только пересоздать индексы ? Т.е. просто выключить и включить. Возможно, даже этого делать не придется, т.к. oncheck все таки умеет перестраивать индексные страницы, поэтому лучше сразу задать ключ Y oncheck -cI y db:table ... |
| 12.04.2007, 12:40 |
vasilis cprдля таблицы logreesdoc oncheck -cI пока только для одного индекса по int-овой колонке прогнал, индекс валидный. чекать можно только ночью, т.к. тормозит систему прилично. записей много. может таблицу сразу того ... дропнуть и перезагрузить? А зачем, если можно только пересоздать индексы ? Т.е. просто выключить и включить. Возможно, даже этого делать не придется, т.к. oncheck все таки умеет перестраивать индексные страницы, поэтому лучше сразу задать ключ Y oncheck -cI y db:table дело в том что у меня вообще есть сомнения, что здесь проблема в индексах. для второй таблицы все индексы и данные валидны, но oncheck -cc выдает ISAM error: illegal key descriptor (too many parts or too long). и прекращает работу вообще. ... |
| 12.04.2007, 12:49 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608414]: |
156ms |
45ms |
| others: | 207ms |
| total: | 450ms |
