IBM Informix .NET Provider
Уважаемые коллеги! Не получается соединиться с сервером Informix (пробовал версии 5,9,10) из "Visual Studio 2005" при помощи родного провайдера "IBM Informix .NET Provider" из версии "Informix Connect 2.90tc5": string connectionString = "Host=xxx; Service=xxx; Server=xxx;" + "User ID=xxx; password=xxx; Database=xxx;" + "Client Locale=xxx;Database Locale=xxx;"; IfxConnection conn = new IfxConnection(connectionString); conn.Open(); Возникает исключение "InvalidOperationException": ERROR - невозможно выделить хэндл среды Под ODBC всё соединяется замечательно Что не так, может, кто сталкивался? ... |
| 04.10.2006, 14:50 |
По сути заголовка, но не предыдущего сообщения :) IBM Informix Client SDK 3.0 and IBM Informix Connect Runtime 3.0 support .NET Framework 2.0 A new data provider for Informix Client SDK V3.0 and its runtime product IBM Informix Connect Runtime (RT) V3.0 allows .NET applications to access IDS by using the common base classes that are declared in the System.Data.Common namespace. The .NET Framework 2.0 support for IDS V7.31, V9.4, and V10.00 on the Windows platform enables development of a generic .NET database application without referencing any data provider-specific classes. It provides IBM Database Add-Ins for Microsoft Visual Studio 2005, which is a collection of add-ins to the Microsoft Visual Studio .NET IDE, simplifying the creation of IDS applications that use the ADO.NET 2.0 interface. Client SDK V3.0 also contains significant performance improvements to the .NET data provider. Informix Connect RT V3.0 is a runtime connectivity product that includes the runtime libraries of the Informix Client SDK are required by applications running on client machines when accessing Informix servers. Informix Connect RT is needed when finished applications are ready to be deployed. http://www-306.ibm.com/common/ssi/rep_ca/8/877/ENUSZP07-0168/ENUSZP07-0168.PDF ... |
| 18.04.2007, 11:47 |
Надеюсь, скрипт .../informix/etc/sdotnet.sql - выполнял на сервере ? С уважением, Вадим. ... |
| 18.04.2007, 12:30 |
GVF112GVFНадеюсь, скрипт .../informix/etc/sdotnet.sql - выполнял на сервере ? Вадим, а ты кого спрашиваешь ? Надеюсь, что не меня, а "Sergey Ivankin", который задавал вопрос ПОЛ-ГОДА назад :)) и с тех пор больше не появлялся... ... |
| 18.04.2007, 17:59 |
Вася, ты лучше скажи как решился вопрос с AIX ... :) С уважением, Вадим. ... |
| 19.04.2007, 10:40 |
GVF112GVFВася, ты лучше скажи как решился вопрос с AIX ... :). Пока не падает :) ... |
| 19.04.2007, 21:09 |
Уже хорошо ... :) До встречи, Вадим. ... |
| 19.04.2007, 22:09 |
GVF112GVFВася, ты лучше скажи как решился вопрос с AIX ... :) С уважением, Вадим. Вы случайно не о Ростове? ... |
| 20.04.2007, 15:52 |
Нет они в Киеве... А что в у вас проблемы с IDS+AIX??? ... |
| 20.04.2007, 16:07 |
По слухам проблема вроде решена. ... |
| 20.04.2007, 16:11 |
sysmaster GVF112GVFВася, ты лучше скажи как решился вопрос с AIX ... :) С уважением, Вадим. Вы случайно не о Ростове? а где в Ростове AIX+Informix? ... |
| 22.04.2007, 04:55 |
nkulikovНет они в Киеве... А что в у вас проблемы с IDS+AIX??? Да, были маленько... Сервер IDS 9.40.FC6 падал на построении больших автоиндексов. Возможно и сейчас упадет :) (Просто их все построили и больше не пытались). Инсталляция специфическая (не raw, нет KAIO, RAID5, один большой чанк на 300Г и т.п.) ... |
| 25.04.2007, 16:16 |
Ну вообщето не рекомендуется иметь файлы под БД (chunk, container) размером больше 35GB. Так как contention на уровне файловой системы начинается (вне зависимости от OS) ... |
| 26.04.2007, 10:37 |
Ну, я же говорил, что "Инсталляция специфическая", там много такого, что очень мне не нравится, но "так сложилось исторически" и удастся ли поправить - пока неизвестно. А вот насчет цифры в 35Г - никогда не видел каких -либо рекомендаций Informix на этот счет. ... |
| 26.04.2007, 11:29 |
для DB2 и Oracle это есть. В принципе верно и для Informix'a тоже. Физика ФС начинает тормозить. ... |
| 26.04.2007, 18:24 |
nkulikovдля DB2 и Oracle это есть. В принципе верно и для Informix'a тоже. Физика ФС начинает тормозить. А если без ФС, то этот недостаток уже не проявляется ? Т.е. на raw можно чанки на сотни гиг ? У меня есть еще подозрения, что и сам IDS не может эффективно работать несколькими нитями параллельно с одним большим чанком, но это только подозрения... ... |
| 26.04.2007, 20:42 |
Про ограничения на raw ограничений не помню. ... |
| 27.04.2007, 06:54 |
vasilisА если без ФС, то этот недостаток уже не проявляется ? Т.е. на raw можно чанки на сотни гиг ? У меня есть еще подозрения, что и сам IDS не может эффективно работать несколькими нитями параллельно с одним большим чанком, но это только подозрения...Почему подозрения? Там архитектурно заложено, например только один клинерс. ... |
| 27.04.2007, 08:45 |
Журавлев Денис vasilisА если без ФС, то этот недостаток уже не проявляется ? Т.е. на raw можно чанки на сотни гиг ? У меня есть еще подозрения, что и сам IDS не может эффективно работать несколькими нитями параллельно с одним большим чанком, но это только подозрения...Почему подозрения? Там архитектурно заложено, например только один клинерс. Клинерсы понятно - об этом часто пишут. А параллельные сканы с одного чанка кто нибудь видел ? ... |
| 27.04.2007, 14:21 |
vasilis Журавлев Денис vasilisА если без ФС, то этот недостаток уже не проявляется ? Т.е. на raw можно чанки на сотни гиг ? У меня есть еще подозрения, что и сам IDS не может эффективно работать несколькими нитями параллельно с одним большим чанком, но это только подозрения...Почему подозрения? Там архитектурно заложено, например только один клинерс. Клинерсы понятно - об этом часто пишут. А параллельные сканы с одного чанка кто нибудь видел ? Я не совсем понял, а может забыл, почему не может? Если используется KAIO то CPUVP делает read, который управление возвращает сразу же не дожидаясь окончания операции ВВ. Дальше можно запускать другой read, или выполнять код нити. по приходу SIGIO анализируется результат выполнения операции ВВ. AIOVP ждут окончания операции ВВ, но их много. Если их хватает, почему не может быть паралельных сканов? з.ы. ответ можно постить сюда . ... |
| 27.04.2007, 15:06 |
vasilis nkulikovНет они в Киеве... А что в у вас проблемы с IDS+AIX??? Да, были маленько... Сервер IDS 9.40.FC6 падал на построении больших автоиндексов. Возможно и сейчас упадет :) (Просто их все построили и больше не пытались). Инсталляция специфическая (не raw, нет KAIO, RAID5, один большой чанк на 300Г и т.п.) Кто же придумал такую конфигурацию? Вероятнее всего падает когда AIX пытается засвопить разделяемую память. Нужно смотреть man vmo 1. maxpin, v_pinshm=1 ( запретить свопить разделяемую память) 2. maxperm , minterm ( По максимуму зажать буфер файловой системы) Производительности это поубавит и падучести думаю тоже. Дальше смотреть по ходу дела. И менять структуру базы. Прошу прощения за резкость высказываний, но это не инсталляция, а дискредитация платформы и СУБД. ... |
| 27.04.2007, 16:07 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608397]: |
157ms |
40ms |
| others: | 242ms |
| total: | 475ms |
