Debian and Ubuntu supported with IDS 11.10XC1 !
IDS team would like to share with you that Debian and Ubuntu are now supported with Cheetah IDS 11.10XC1. Please refer following details to ensure you have right versions of compiler, Kernel and glibc installed on your machines: For IDS X86 ( Linux 32) on Debian GNU/Linux 4.0 : Compiler : 4.1.2 glibc : 2.3.6 Kernel :2.6.18-4-686 Comments: Install the following: - libaio1 (required for KAIO) - pdksh (required by ISM) For IDS X86_64 ( Linux 64) on Debian GNU/Linux 4.0: Compiler : 4.0.3 glibc : 2.3.6 Kernel : 2.6.15 Comments: Install the following: - libaio1 (required for KAIO) - pdksh, Libc6-i386, libncurses 32bit (required by ISM) Note: - libncurses 32bit(required for ISM)needs to be copied from a x86 (32-bit) installation. - Copy /lib/libncurses.so.5 from x86 (32bit) installation to x86_64(64bit)32bit compat libs: /lib32/libncurses.so.5 For IDS X86 ( Linux 32) on Ubuntu 6.0.6.1 LTS : Compiler : 4.0.3 glibc : 2.3.6 Kernel : 2.6.15 Comments: Install the following: - libaio1 (required for KAIO) - pdksh (required by ISM) - bc utility (required by installserver) For IDS X86_64 ( Linux 64) on Ubuntu 6.0.6.1 LTS : Compiler : 4.0.3 glibc : 2.3.6 Kernel : 2.6.15 Comments: Install the following: - libaio1 (required for KAIO) - pdksh, Libc6-i386, libncurses 32bit (required by ISM) - bc utility (required by installserver) Note: - libncurses 32bit(required for ISM)needs to be copied from a x86 (32-bit) installation. - Copy /lib/libncurses.so.5 from x86 (32bit) installation to x86_64(64bit)32bit compat libs: /lib32/libncurses.so.5 ... |
| 03.09.2007, 22:43 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608316]: |
169ms |
| others: | 239ms |
| total: | 468ms |
