Informix crash
Получаю краш информикса. Почему? online.log15:02:05 Log Record: log = 42, pos = 0xc6f120, type = OLDRSAM:ADDITEM(28), trans = 16 15:02:05 Rollforward of log record failed. iserrno = 135 15:02:05 Log Record: log = 42, pos = 0xc6f120, type = OLDRSAM:ADDITEM(28), trans = 16 15:02:05 Rollforward of log record failed. iserrno = 101 15:02:05 Log Record: log = 42, pos = 0xc70364, type = OLDRSAM:UNIQID(17), trans = 16 15:02:05 Rollforward of log record failed. iserrno = 101 15:02:05 Log Record: log = 42, pos = 0xc70364, type = OLDRSAM:UNIQID(17), trans = 16 15:02:05 stack trace for pid 22185 written to /informix/tmp/af.3fbb43f 15:02:05 Assert Failed: No Exception Handler 15:02:05 IBM Informix Dynamic Server Version 10.00.UC3R1 15:02:05 Who: Session(7, informix@kdb7-pri1-40.euprimev.tsys, 0, 0xb20b9e18) Thread(19, xchg_1.0, b20923d0, 1) File: mtex.c Line: 435 15:02:05 Results: Exception Caught. Type: MT_EX_OS, Context: mem 15:02:05 Action: Please notify IBM Informix Technical Support. 15:02:05 stack trace for pid 22185 written to /informix/tmp/af.3fbb43f 15:02:05 See Also: /informix/tmp/af.3fbb43f А вот кусок из упомянутого файла: автор===========------------- - - - - - - /informix/bin/oninit -V: IBM Informix Dynamic Server Version 10.00.UC3R1 Software Serial Number AAA#B000000 Mon Aug 1 12:44:40 CDT 2005 ===========------------- - - - - - - /informix/bin/onstat -V: IBM Informix Dynamic Server Version 10.00.UC3R1 Software Serial Number AAA#B000000 ===========------------- - - - - - - /informix/bin/oncheck -V: IBM Informix Dynamic Server Version 10.00.UC3R1 Software Serial Number AAA#B000000 ===========------------- - - - - - - /informix/bin/onmode -V: IBM Informix Dynamic Server Version 10.00.UC3R1 Software Serial Number AAA#B000000 ===========------------- - - - - - - uname -a: Linux kdb7-pri1-40.euprimev.tsys 2.6.9-67.ELsmp #1 SMP Wed Nov 7 13:58:04 EST 2007 i686 i686 i386 GNU/Linux ------------------------------- End System Alarm Program Output ------------------------------- 14:50:33 sh /informix/etc/evidence.sh 3 0 /informix/tmp/af.3fbb18c 7 0xb20923d0 19 0xb2e1d7d8 1537 0 0 0 0 14:50:33 ------------------ End of assertion failure 2 ----------------- Подскажите а то даже стартовать его не могу заново... ... |
| 12.02.2008, 18:17 |
Informix crash
# finderr -135 -135 ISAM error: tblspace does not exist. This error might indicate corruption of control information in the root dbspace, a serious problem that might require restoring the system from archive. In the short term, roll back the current transaction, and terminate the application. Then the database server administrator should run the tbcheck, oncheck, or onutil utility. # finderr -101 -101 ISAM error: file is not open. The program attempted to use an unopened file, table, partition, tablespace, or other storage object, or one of these whose access mode did not support the requested operation (for example, an attempt to write to a file that was opened in read-only mode). ---------------------------------------------------------- Поднять то его можно - но если он не подымается сам, то это все танцы с бубном. Эти танцы вроде как обсуждались и не раз - ищи. А воще - подниматься с архива и не париться. Кстати - это у вас случайно не вторичный сервер реппликации HDR? На вторичных серверах подобное периодически бывает. ... |
| 12.02.2008, 23:58 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608168]: |
80ms |
49ms |
| others: | 236ms |
| total: | 416ms |
