Cannot write sorted rows
Итак при откритии базы в ServerStudio и попытке просмотреть список процедур получаю ошибку Cannot Write Sorted Rows. Смотрю на наличие свободного места на сервере (onstat -d): авторInformix Dynamic Server Version 9.30.TC1 -- On-Line -- Up 00:27:42 -- 25472 Kbytes Dbspaces address number flags fchunk nchunks flags owner name c9e27d0 1 0x2 1 1 M informix rootdbs c9e2d88 2 0x1 2 1 N informix logdbs c9e2ed0 3 0x1 3 4 N informix dbs1 3 active, 2047 maximum Chunks address chk/dbs offset size free bpages flags pathname c9e2918 1 1 0 12800 7812 PO- C:\IFMXDATA\AOPServer\rootdbs_dat.000 c9e2a80 1 1 0 12800 0 MO- D:\IFMXDATA\AOPServer\rootdbs_mirr.000 ca37b08 2 2 0 25000 17947 PO- c:\ifmxdata\aopserver\logdbs ca37c70 3 3 0 25000 29 PO- c:\ifmxdata\aopserver\dbs1 ca37dd8 4 3 0 250000 48015 PO- c:\ifmxdata\aopserver\dbs1_2 ca28e30 5 3 0 62500 62497 PO- c:\IFMXDATA\AOPSERVER\dbs1_3 c9e2c20 6 3 0 500000 499897 PO- d:\informix\dbs1 6 active, 2047 maximum По DB.log вижу вот что: авторMon Aug 25 11:16:00 2008 11:16:00 Booting Language <c> from module <> 11:16:00 Loading Module <CNULL> 11:16:00 Booting Language <builtin> from module <> 11:16:00 Loading Module <BUILTINNULL> 11:16:04 Informix Dynamic Server Version 9.30.TC1 Software Serial Number AAC#J837981 11:16:06 Informix Dynamic Server Initialized -- Shared Memory Initialized. 11:16:06 Physical Recovery Started at Page(1:476). 11:16:21 Physical Recovery Complete: 0 Pages Examined 0 Pages Restored. 11:16:21 Logical Recovery Started. 11:16:21 10 recovery worker threads will be started. 11:16:21 Dynamically allocated new virtual shared memory segment (size 8192KB) 11:16:24 Logical Recovery has reached the transaction cleanup phase. 11:16:24 Logical Recovery Complete. 0 Committed, 0 Rolled Back, 0 Open, 0 Bad Locks 11:16:25 Dataskip is now OFF for all dbspaces 11:16:25 Checkpoint Completed: duration was 0 seconds. 11:16:25 Checkpoint loguniq 2068, logpos 0x133018 11:16:25 Maximum server connections 0 11:16:26 Init operation complete - Mode Online 11:16:26 On-Line Mode 11:16:33 Booting Language <spl> from module <> 11:16:33 Loading Module <SPLNULL> 11:21:55 Checkpoint Completed: duration was 0 seconds. 11:21:55 Checkpoint loguniq 2068, logpos 0x134018 11:21:55 Maximum server connections 1 11:41:56 Checkpoint Completed: duration was 0 seconds. 11:41:56 Checkpoint loguniq 2068, logpos 0x136018 11:41:56 Maximum server connections 3 Как побороть? ... |
| 25.08.2008, 11:47 |
Читать доку. Создайте временное пространство и пропишите его в онконфиге Либо установите dbs1 как DBSPACETEMP Можно конечно посмотреть в сторону DBTEMP ... |
| 25.08.2008, 12:54 |
Добавил - все равно то же самое. авторInformix Dynamic Server Version 9.30.TC1 -- On-Line -- Up 05:18:03 -- 66624 Kbytes Dbspaces address number flags fchunk nchunks flags owner name c9e27d0 1 0x2 1 1 M informix rootdbs c9e2d88 2 0x1 2 1 N informix logdbs c9e2ed0 3 0x1 3 4 N informix dbs1 100e3cb0 4 0x2001 7 1 N T informix tempdbs 4 active, 2047 maximum Chunks address chk/dbs offset size free bpages flags pathname c9e2918 1 1 0 12800 7812 PO- C:\IFMXDATA\AOPServer\rootdbs_dat.000 c9e2a80 1 1 0 12800 0 MO- D:\IFMXDATA\AOPServer\rootdbs_mirr.000 ca37b08 2 2 0 25000 17947 PO- c:\ifmxdata\aopserver\logdbs ca37c70 3 3 0 25000 29 PO- c:\ifmxdata\aopserver\dbs1 ca37dd8 4 3 0 250000 46863 PO- c:\ifmxdata\aopserver\dbs1_2 ca28e30 5 3 0 62500 62497 PO- c:\IFMXDATA\AOPSERVER\dbs1_3 c9e2c20 6 3 0 500000 499897 PO- d:\informix\dbs1 100e3df8 7 4 0 12500 12447 PO- d:\informix\tempdbs 7 active, 2047 maximum ... |
| 25.08.2008, 16:34 |
Петров АндрейДобавил - все равно то же самое. если вы прописали DBSPACETEMP в онконфиге то информикс заметит это при рестарте. если перестартовывать нельзя то DBSPACETEMP это не только переменная в онконфиге но и переменная среды ... |
| 25.08.2008, 16:42 |
start [/forum/topic.php?desktop=1&fid=44&tid=1608030]: |
143ms |
25ms |
| others: | 254ms |
| total: | 453ms |
