Multicarta relies on IBM Informix for Credit Card Authorization (Russia)
Multicarta Ltd., a Russian credit card authorization processor, relies on IBM IDS running in a Linux Cluster environment with SteelEye LifeKeeper software: Russian Credit Card Authorization Centre Reduces Downtime To Under 15 Minutes A Year According to the press release, the system availability is about 99.997% (15 minutes max downtime per year). This sounds quite good from an availability point of view. However this is still a traditional active/passive cluster. Moving to the IDS MACH11 technology would allow them to dynamically scale the IDS cluster by adding additional SDS nodes on the fly, achieving load balancing thru the connection manager, replicating the data to a disaster recovery center via HDR or keeping bunker backups via RSS. These are some of the benefits that the MACH11 technology offers in comparison to a traditional active/passive cluster. Подробнее здесь . ... |
| 03.12.2008, 20:15 |
sysmasterMulticarta Ltd., a Russian credit card authorization processor, relies on IBM IDS running in a Linux Cluster environment with SteelEye LifeKeeper software: Russian Credit Card Authorization Centre Reduces Downtime To Under 15 Minutes A Year According to the press release, the system availability is about 99.997% (15 minutes max downtime per year). This sounds quite good from an availability point of view. However this is still a traditional active/passive cluster. Moving to the IDS MACH11 technology would allow them to dynamically scale the IDS cluster by adding additional SDS nodes on the fly, achieving load balancing thru the connection manager, replicating the data to a disaster recovery center via HDR or keeping bunker backups via RSS. These are some of the benefits that the MACH11 technology offers in comparison to a traditional active/passive cluster. Подробнее здесь . Очень Интересно, есть несколько вопросов: 1. Cколько автризационных запросов в сутки делает эта система ? 2. Сколько в секунду в пике ? 3. Какая глубина истории в базе ( в количестве транзакций или времени). 4. автор achieving load balancing thru the connection manager Какой connection manager используется ? 5. Кто разработчик процессигового софта? Если не секрет. ... |
| 03.12.2008, 21:16 |
Собственно, если бы кто-то вместо Княжичей побывал бы неделю назад в Киеве. Он бы знал, что в 11-й версии у Informix-а появился свой Connection Manager. Собственно эта же новость, но со ссылками на использованные технологии. ... |
| 04.12.2008, 08:40 |
Собсвтенно Мультикарта - это процессинг имени ВТБ. последние цифры правда за 2005-й год, но думаю взвесить можно, по украинским меркам карманный процессинг средних размеров (чуть меньше ПУМБ-а). ... |
| 04.12.2008, 08:53 |
Скажите хотя бы какая версия IDS - 11.1 или 11.5 (желательно вплоть до релиза). ... |
| 04.12.2008, 14:08 |
Упс. Ссылочку я не аккуратно привел, в тегах запутался. Подправил в исходном посте. Информации там не больше, чем в исходном мессаге. Просто есть рассказ кто такой MACH11 и connection manager. ... |
| 04.12.2008, 14:21 |
start [/forum/topic.php?desktop=1&fid=44&tid=1607941]: |
23ms |
142ms |
57ms |
| others: | 226ms |
| total: | 477ms |
