create a UDR-procedure in java that will return multiple types data in IDS
We installed: IBM Informix Dynamic Server Version 10.00.UC6 JDBC – 3.00 J2SE 1.4.2 On operational system Red Hat Enterprise Linux AS release 4 (Nahant) 2.6.9-5.EL We create a UDR-procedure in java that will return multiple types data in IDS. We realized java file. We compiled and created the jar. class test { public static int two_return(java.lang.Integer [] i, String [] s){ i[0]= new java.lang.Integer (5); s[0]=”OK”; return 0; } } Then we installed the jar: EXECUTE PROCEDURE install_jar ("file:$INFORMIXDIR/extend/krakatoa/Test_j.jar", "Test_j", 0); Created function for IDS: CREATE FUNCTION test_return (OUT a integer, OUT s char(5)) returns int external name 'Test_jar:test.two_return (java.lang.Integer [], java.lang.String)' language java; ALTER FUNCTION test_return (ADD HANDLESNULLS); tried call function: SELECT a, s FROM systable WHERE tabid=1 AND test_return (a#integer, s#char(5))=0; result of execution select above, error appears: Error (-937): Cannot find class for type(). LOG: Installing jar test.informix.Test_j... ADDING TO JARMAP: test.informix.Test_j + informix.jvp.dbapplet.impl.JVPClassLoader@5797b5ce PARAM is not NULL Questions: Why appears the error and how to achieve the above-named task? ... |
| 19.02.2009, 16:14 |
start [/forum/topic.php?desktop=1&fid=44&tid=1607889]: |
144ms |
| others: | 252ms |
| total: | 451ms |
