Addition of sub-capacity parts for IBM ... Informix Dynamic Server
Addition of sub-capacity parts for IBM DB2 Linux , UNIX , and Windows , and IBM Informix Dynamic Server At a glance ... IBM Informix® Dynamic Server V11.50 helps you achieve: Reduced hardware costs and deployment complexity Easy-to-deploy and scalable cluster solutions with continuous availability Seamless high-availability application deployment and workload distribution on clusters Dynamic scaling with additional cluster nodes with no interruption to applications Dynamic connection routing, reconnect client application to another node on node failure Global multiple remote failover sites Active-Active reads and writes to secondary servers Up to two active read secondary servers on the Workgroup Edition Sub-capacity pricing to all IDS V11.50 editions: Express, Workgroup, Enterprise ... With IDS V11.50, you will be able to deploy High-availability Data Replication (HDR) with no additional feature charge for the Workgroup Edition, deploying up to two secondary servers in either Idle standby or Hot active read mode. Hot active secondary servers are now eligible for sub-capacity pricing on the Processor Value Unit metric. ... |
| 30.03.2009, 10:05 |
В дополнение, The changes for IDS 11.50 are: ------------------------------ * Sub-capacity licensing is now available for Express and Workgroup Editions * Include HDR for the Workgroup Edition at no extra charge - Increase up to 2 HDR secondary nodes - Read only on secondary nodes, no writes - (Note: Writes to any and all secondary nodes will be on the Enterprise Edition for both primary and all secondary nodes.) * Remove Parallel Performance Feature for Workgroup to provide more edition differentiation - Parallel query, parallel index, parallel load, high performance loader, parallel backup/restore, and table/index/dbspace partitioning are now only available on the Enterprise Edition with new licenses - We have grandfathered Workgroup Edition license holders before 10 February 2009 to have entitlement to use the above parallel functions. Benefits for customers: ---------------------- * More flexibility to deploy IDS Express or Workgroup Editions in virtual servers for server consolidation or capacity management. * Potential cost savings with more flexibility in deployment, where they can deploy a virtual domain with a smaller configuration using Express or Workgroup Edition. * Increase High-Availability (HA) for SMB customers who need to have more than 1 standby node to failover for their disaster recovery plan, but they do not have the budget to go up to the Enterprise Edition. * Greater resource utilization on HDR secondary nodes. Customers on the Workgroup Edition could enjoy greater HA, while they can also utilize up to 2 secondary nodes to do real work, such as generating reports, allow segmented data access, balance workloads, plan for peak usage, etc. and so on ... :) С уважением, Вадим. ... |
| 30.03.2009, 13:44 |
GVF112GVF * Include HDR for the Workgroup Edition at no extra charge ... Справедливости ради, нужно заметить, что хоть на вышеуказанный HDR соотвующие HDR-лицензии уже покупать не нужно, но цена лицензии на сам Информикс увеличилась... Поэтому кажущейся с первого взгляда существенной экономии не получится. ... |
| 30.03.2009, 15:38 |
svat2GVF112GVF * Include HDR for the Workgroup Edition at no extra charge ... Справедливости ради, нужно заметить, что хоть на вышеуказанный HDR соотвующие HDR-лицензии уже покупать не нужно, но цена лицензии на сам Информикс увеличилась... Поэтому кажущейся с первого взгляда существенной экономии не получится. Возможно, что Вы правы, но это лучше, чем было раньше .... :) На счет цен - так они растут не только в IBM. Например, у ORACLE за последний год они выросли на 58% - кризи .... :) С уважением, Вадим. ... |
| 30.03.2009, 16:23 |
GVF112GVF На счет цен - так они растут не только в IBM. Например, у ORACLE за последний год они выросли на 58% - кризи .... :) Правильно писАть - крейзи :) ... |
| 30.03.2009, 17:47 |
АнатоЛойGVF112GVF На счет цен - так они растут не только в IBM. Например, у ORACLE за последний год они выросли на 58% - кризи .... :) Правильно писАть - крейзи :) Я имел ввиду на протяжении последних 12 месяцев ... Сам такой - ... писАть ... не писАть ... дело молодое ... крейзи ... :) С уважением, Вадим. ... |
| 31.03.2009, 18:32 |
start [/forum/topic.php?desktop=1&fid=44&tid=1607856]: |
142ms |
50ms |
| others: | 209ms |
| total: | 443ms |
