Нестандартное поведение FOR в SPL
The general form of the IDS SPL For loop is... Код: plaintext 1. 2. 3. 4. 5. The STEP clause is optional. If it is not provided, the StepVal defaults to 1, unless StartVal > EndVal, in which case it defaults to -1 All this is documented in http://publib.boulder.ibm.com/infocenter/idshelp/v115/index.jsp?topic=/com.ibm.sqls.doc/ids_sqs_1326.htm&resultof=%22%66%6f%72%22%22%6c%6f%6f%70%22 Please alter the SQL syntax documentation to more clearly describe the behavior of the "FOR" statement when the left_expression is numerically greater than the right_expression. The documentation currently states: "The size of right_expression relative to left_expression determines if the range is stepped through by positive or negative increments." A suggested rewording is: "If the STEP clause is not provided, the increment_expr will default to 1, unless left_expression > right_expression, in which case it will default to -1" ... |
| 21.09.2010, 09:25 |
start [/forum/topic.php?desktop=1&fid=44&tid=1607483]: |
194ms |
| others: | 253ms |
| total: | 506ms |
