IBM Informix Database Driver for Perl DBI Version 2011.0612 (2011-06-12) release
After 3 years and 1 month bar 1 day, a new version of DBD::Informix hits the streets - well, CPAN, anyway. The primary change - support for Perl 5.14.0. IBM Informix Database Driver for Perl DBI Version 2011.0612 (2011-06-12) has been uploaded to CPAN. IBM Informix Database Driver for Perl (also known as DBD::Informix) is the driver code that enables Perl 5.6.1 or later to access Informix databases via the DBI module (but if you are not already using Perl 5.10.0 - or any later version - you should be planning to upgrade to Perl 5.14.0 or later). You will need the code for DBI version 1.38 or later as well (v1.616 - or any later version - is recommended). The code for DBD::Informix is available for download via: http://www.perl.org/CPAN/modules/by-category/07_Database_Interfaces http://dbi.perl.org/ ....................... Полный текст http://groups.google.com/group/comp.databases.informix/browse_thread/thread/c8db2340b23bfd99# ... |
| 14.06.2011, 22:04 |
start [/forum/topic.php?desktop=1&fid=44&tid=1607335]: |
45ms |
38ms |
| others: | 242ms |
| total: | 363ms |
