Informix 12.10.xC3
IBM has just released Informix 12.10.xC3 this last Friday (March 14). The packages were available on FixCentral since the beginning of the week, but the documentation was updated only on Friday. As usual for a few years each fixpack contains small improvements and a few gems. This one is no exception. Here is the list directly from the documentation with a few comments added: Migration Server changes JSON compatibility pre- and post-migration requirements New reversion requirements These are "just" some new parameters and things we should consider when upgrading or downgrading. I will refer to some of them later Installation Server configuration Automatically configure the server during installation If we choose to configure a server during installation, resources are adjusted automatically and the JSON listener is started Administration Autonomics Automatic resource tuning for performance Some of the new parameters mentioned above are relevant to this. As an example we can have a dynamic buffer pool, let the server create more logical logs, let it adjust the physical log size and reconfigure the CPU and AIO VPs. This is another great step in the autonomic chapter. Automatic location and fragmentation Another major change. If you prefer (set AUTOLOCATE parameter) the new tables are automatically created in a set of dbspaces, and fragmented in round-robin. If the tables grow, new fragments are automatically created. No more "no more pages" errors. For the old timer DBA (like me) this sounds tricky... but times do change and we must keep up. You're not forced to use this, but it will probably fit some environments Performance Control the size of private memory caches In previous fixpacks the private memory caches used by each CPU VP changed to dynamic. Now you have the option to make them static Virtual shared memory segment size doubling Like we do in the extents for the tables, each 16 memory segments that we allocate we double their size. The idea is to keep their number low. But again, for old timers, 16 is already a very large number. We usually try to keep them below 5 (?). But this also means we can have them lower initially because we know that if the server grows to much, it will adapt. Connectivity Retrying connections As we've seen in 11.70.xC8, we can now define INFORMIXCONTIME and INFORMIXCONRETRY as $ONCONFIG parameters and by using the SET ENVIRONMENT statement. This seems nice but to be honest I was not really getting it (I should have noticed it when I wrote about 11.70.xC8). My confusion is caused by the fact that I usually use these settings to avoid spending too much time trying to connect to a dead or unreachable server. But if we cannot reach the server how would having these settings on the server side help?! Because this is to be applied on distributed queries and for that it makes sense. Application development JSON compatibility Use the MongoDB API to access relational data You can access relational tables with the MongoDB API methods Improved JSON compatibility New MongoDB API methods are supported like findAndModify() and some authentication related operations Foreign-key constraints Temporarily prevent constraint validation As in 11.70.xC8 this introduces the ability to use NOVALIDATE on foreign-key constraints creation to speed up the process Faster creation of foreign-key constraints As in 11.70.xC8, real creation of foreign keys can take better advantage of existing indexes Compatibility Find the quarter of the calendar year for dates Implementation of the QUARTER() SQL function. A request from the market for better integration with 3rd party BI tools High-availability clusters and Enterprise Replication Connection Manager Improvements to Connection Manager Introduction of two new redirection policies: ROUNDROBIN and SECAPPLYBACKLOG Monitoring View log-staging information on RS secondary servers Get information about log staging information in RSS servers where the DELAY APPLY functionality is in use Configuration Easier configuration and cloning of a server for replication Easily configure and start Enterprise Replication Sharding Shard data across Enterprise Replication servers Shard is a term that refers to the distribution of a single object across a number of nodes. The purpose is a bit like "divide and conqueror". By distributing records, documents or rows we make them more manageable in each node and gain performance by having more hardware dealing with our data. Informix can now "shard" relational tables and collections (JSON) across instances in an Enterprise Replication domain Spatial data Enhancements for handling spatial data More spatial reference systems and the ability to calculate area and distance for data based on the round-Earth model. Informix spatial data types now conform to the OpenGIS Simple Features Specification for SQL Revision 1.1 and the ISO/IEC 13249-3 SQL/MM Part 3: Spatial. The Informix spatial solution is based on the ESRI SDE 10.2 Shape and PE libraries. Time series data Storage Efficient storage for hertz and numeric time series data Timeseries can store a series of sub-second values in a packed element (up to 4KB) Containers Control the destroy behavior for rolling window containers Limit the number of windows of a rolling window container that can be destroyed in a single operation Monitor groups of containers with wildcard characters Several monitorization functions now allow wildcards in the container name Faster queries Faster queries by running time series routines in parallel Functions that can be used in WHERE clause of a SELECT statement now can take advantage of PDQ PRIORITY (parallelism) if the tables are fragmented Faster queries with IN conditions through virtual tables Optimization for queries with IN conditions Warehousing Additional types of data Accelerate warehouse queries in-memory using data from multiple sources Synonyms and views can now reference tables in different databases, tables in databases of the same Informix instance, or tables in a different Informix instance. This work for JSON data also Beyond the very light review above, I'd like to highlight a few points: Dynamic buffer pool. Although currently it can "only" be set to self tune (it will grow within specified limits if the read cache hits are lower than a threshold we define), this will be an historical step. I remember that while explaining the dynamic parameters we were introducing, I sometimes mentioned that "some like BUFFERPOOL will possibly never be dynamic".... Well, I must rethink that statement. Although currently it's not dynamic, if it can automatically adjust the buffers, I imagine we'll be able to do the same in the future (by using onmode -wm/wf for example) You may noticed that some features introduced in xC3 of version 12.10 were already introduced in xC8 of version 11.70. This happens because some features are being developed across more than one code line, and they appear first in version N-1 or N depending on the release schedule and calendar. Nothing to do with marketing... If the code change is feasible in more than one version we give it to customers. We don't force them to upgrade to get any new stuff. How many vendors incorporate new features in previous product versions?! Continuous improvements in many distinctive areas: Timeseries, JSON, IWA. ... |
| 19.03.2014, 12:37:25 |
Informix 12.10.xC3
наконец-то появилась функция получения плана SQL-запроса без использования хитромудрых способов: Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. ... |
| 19.03.2014, 12:44:19 |
start [/forum/topic.php?desktop=1&fid=44&tid=1606977]: |
90ms |
31ms |
| others: | 210ms |
| total: | 377ms |
