Do I need to learn R?
FYI ... Informix with R ... Do I need to learn R? Four good reasons to try the open source platform for data analysis R is a flexible programming language designed to facilitate exploratory data analysis, classical statistical tests, and high-level graphics. With its rich and ever-expanding library of packages, R is on the leading edge of development in statistics, data analytics, and data mining. R has proven itself a useful tool within the growing field of big data and has been integrated into several commercial packages, such as IBM SPSS® and InfoSphere®, as well as Mathematica. This article offers a statistician's perspective on the value of R http://www.ibm.com/developerworks/opensource/library/bd-learnr/index.html ... |
| 09.04.2014, 12:17 |
GVF112GVF, а как цепляться из этого R к Informix, через ODBC ? ... |
| 09.04.2014, 14:06 |
ifmxuser, The R language does not include built-in relational database access capability, but there are many data access interfaces available from vendors or through the Comprehensive R Archive Network (CRAN). For example - Connecting with RJDBC, Connecting with RODBC ... Using R with databases - http://www.ibm.com/developerworks/data/library/techarticle/dm-1402db2andr/index.html?ca=drs Kind regards, Vadim. ... |
| 09.04.2014, 15:52 |
GVF112GVFThe R language does not include built-in relational database access capability хорошо, но при чем здесь ветка Informix ? :) ... |
| 09.04.2014, 16:09 |
ifmxuser, Эта информация скорее всего для разработчиков Informix которые хотят использовать возможности языка R для аналитических задач. Для кругозора - язык "R" уже интегрирован во многие решения IBM Big Data - IBM BigInsights, IBM Streams, DB2 BLU и т.д. Далее, решение IBM Informix TimeSeries входит в состав IBM Big Data. Есть возможность интеграции IBM Informix + IBM Streams with R и т.д. С уважением, Вадим. ... |
| 10.04.2014, 10:11 |
start [/forum/topic.php?desktop=1&fid=44&tid=1606971]: |
93ms |
45ms |
| others: | 246ms |
| total: | 439ms |
