Tune logical and physical log automatically
FYI ... Tune logical and physical log automatically - http://www.iiug.org/Insider/insider_apr14.php#IC.1 Starting with version 12.10.xC3 Informix can automatically tune the logical and physical log as needed. You can set the AUTO_LLOG configuration parameter to enable Informix to dynamically add logical logs when lack of logical logs causes frequent checkpoints, blocking checkpoints, long checkpoints etc. In addition, with AUTO_LLOG configuration parameter you can specify a dbspace in which to create new logical log files and the size of all logical log files at which the server stops adding logs for performance. ... Kind regards, Vadim. ... |
| 03.05.2014, 22:14 |
start [/forum/topic.php?desktop=1&fid=44&tid=1606957]: |
77ms |
| others: | 230ms |
| total: | 357ms |
