Select select
С НАСТУПАЮЩИМ!!! Подскажите можно лт в db2 (по образу сиквела) select col, (select count(*) from table2 where col2 = t1.col2) from table1 t1 ... |
| 26.12.2003, 11:24:54 |
Select select
Есть такое: select T1.field ,T2.field from table t1 ,(select field from table2) AS T2 ... |
| 26.12.2003, 12:24:58 |
Select select
Можно и SELECT T1.ID, (SELECT COUNT(*) FROM T2 WHERE T2.FIELD_OUT = T1.ID) AS T2_COUNT FROM T1 ... |
| 26.12.2003, 17:31:35 |
Select select
Вот такой запрос Select (select count(*) from zzz.STLIST s1) as r1 from zzz.STLIST s дает такую ошибку [IBM][CLI Driver][DB2] SQL0104N An unexpected token "COUNT" was found following "". Expected tokens may include: "+ ) - ". SQLSTATE=42601 делаю в 7.1 на ос390 может на такой еще нету ... |
| 29.12.2003, 06:29:45 |
start [/forum/topic.php?desktop=1&fid=43&tid=1606387]: |
742ms |
39ms |
| others: | 236ms |
| total: | 1054ms |
