Ожидаем IBM DB/2 UDB FixPack 4a
DB2 Service would like to draw your attention to a high-impact pervasive (HIPER) APAR (defect) that affects DB2 Universal Database Version 8.1 with FixPak 4. APAR number: ============ JR19507 http://www-306.ibm.com/cgi-bin/db2www/data/db2/udb/winos2unix/support/aparlib.d2w/display_apar_details?aparno=JR19507 DB2 version affected: =================== DB2 Universal Database for Linux, Unix, and Windows Version 8.1 with FixPak 4. Description: ========== Under very specific conditions, a SELECT statement on a single column using the DISTINCT keyword may return more results (rows) than expected. This problem will occur only if *all* of the following conditions are satisfied: You are running DB2 Universal Database Version 8.1 with FixPak 4. Earlier versions and FixPak levels are not affected. A SELECT is issued against one (and only one) large integer (4 byte) column. Selecting more than one column, or selecting one column that is anything other than large integer, will not trigger the problem. At least two predicates exist in the statement. No predicates, or just one predicate, will not trigger the problem. The DISTINCT keyword is used. However, this problem is not strictly limited to the use of the DISTINCT keyword. If the plan for any SQL statement chosen by the optimizer calls for establishing the distinctness of a single 'large' integer while applying two or more predicates, this problem can be recreated, but may not be in every case. For example, the following statement satisfies all of the conditions necessary to recreate the problem (setting aside the caveats about distinctness): select distinct c1 from t1 where c1 > 5 and c2 = 'T' However, the following statements do *not* satisfy the conditions necessary to trigger the problem: select distinct c1 from t1 or select distinct c1 from t1 where c1 > 5 Workaround: =========== None. Fix: === This problem will be addressed in FixPak 4a which will be available for download during the week of January 26 at the following web site: ... |
| 27.01.2004, 12:58:44 |
start [/forum/topic.php?desktop=1&fid=43&tid=1606357]: |
203ms |
36ms |
| others: | 229ms |
| total: | 524ms |
