Ошибка диска при BACKUP
Поставил 8-ю версию DB2. Мигрировал старые базы с версии 7.1. Попытался сделать резервную копию, а она мне говорит: "SQL0980C Ошибка диска. Последующие операторы SQL невозможно обработать..." Чего за фигня такая? Диски-то вроде впорядке:) место есть:) ... |
| 28.07.2004, 14:18 |
SQL0980C A disk error occurred. Subsequent SQL statements cannot be processed. Explanation: A disk error occurred that prevented successful execution of the current and subsequent SQL statements. The application program is not permitted to issue additional SQL statements. For example a recovery routine associated with the application program cannot issue additional SQL statements. The database is marked as needing recovery and all applications using the database are prevented from accessing the database. The statement cannot be processed. User Response: Record all error information from the SQLCA, if possible. Terminate all applications using the database. Determine if the error is a hardware error. Restart the database. If recovery is not possible, restore the database from a backup copy. If installing the sample database, drop it and install the sample database again. sqlcode : -980 sqlstate : 58005 ... |
| 28.07.2004, 14:54 |
ДЫК енто все понятно:) только не понятно чего делать-то??? ... |
| 28.07.2004, 15:59 |
start [/forum/topic.php?desktop=1&fid=43&tid=1606180]: |
91ms |
39ms |
| others: | 265ms |
| total: | 444ms |
