Re: Порядок установки FixPack'ов ....
http://www-306.ibm.com/software/data/db2/udb/support/downloadv8.html#WIN-32 Столбец - Prereq To: nkulikov Попутно вопрос про 8-ку: будут ли полноценно с ней работать 7-ные клиенты? (5-ные с 7-кой справляются) ... |
| 28.02.2005, 17:59:36 |
Путь Upgrade your DB2 Version 7 clients to he latest Version 7 FixPak level. Migrate your DB2 Version 7 servers to ersion 8 and upgrade to the latest FixPak level. Migrate your DB2 Connect Version 7 servers to Version 8 and upgrade to the latest FixPak level. Migrate your DB2 clients to Version 8 and upgrade to the latest FixPak level. Optional - Migrate your server from DB2 Version 8 from 32-bit to 64-bit. Ограничения DB2 Version 8 clients can connect to DB2 Version 7 servers only if the DB2 server is running a DRDA Application Server. Refer to the Version 7 Installation and Configuration Supplement for instructions. There are still numerous restrictions, see the “Version 8 incompatibilities with previous releases” topic in the Information Center for more details: publib.boulder.ibm.com/infocenter/db2help/index.jsp?topic=/com.ibm.db2.udb.doc/admin/r0008109.htm DB2 Version 8 clients cannot connect to DB2 Connect Version 7 servers. Upgrade your DB2 Connect servers to Version 8 before you update your DB2 clients to Version 8. No restrictions in connecting DB2 Version 7 32-bit clients to DB2 Version 8 32-bit servers No support for Version 7 32-bit clients connecting to DB2 Version 8 64-bit server. No support for attach from Version 7 32-bit to Version 8 any bit publib.boulder.ibm.com/infocenter/db2help/topic/com.ibm.db2.udb.doc/start/r0009731.htm ... |
| 01.03.2005, 15:14:43 |
start [/forum/topic.php?desktop=1&fid=43&tid=1605984]: |
80ms |
30ms |
| others: | 231ms |
| total: | 386ms |
