OLEDB провайдер к DB2
Добрый день ! Пытаюсь подсоединится к DB2 через OLEDB. - Провайдер от Microsoft ругается "The authentication metod used is not supported by the remote system. SQLSTATE: HY000, SQLCODE: -1004". - Провайдер от IBM вообще "The IBM OLE DB provider is not available at this time". Может, кто чего подскажет? ... |
| 26.04.2005, 11:06 |
Какая версия Db2?? Что стоит на клиенте??? На сервере db2pd -dbmcfg На клиенте db2 get dbm cfg А вообще ошибка говорит SQL1004C There is not enough storage on the file system to process the command. Explanation: There is not enough storage on the specified file system to process the command. In a partitioned database environment on Windows environments, each node in the partitioned database group must have the exact same physical hard drive specification (letter) available and useable (must contain useable space) for the CREATE DATABASE command to succeed. The physical hard drive letter is specified in the database manager configuration. If DFTDBPATH is left blank the default will be the hard drive where DB2 is installed on the instance owning machine (db2 installation path). The command cannot be processed. ... |
| 26.04.2005, 11:49 |
Сервер, клиент - одна машина. Везде стоит 7.2.1 ... |
| 26.04.2005, 12:43 |
start [/forum/topic.php?desktop=1&fid=43&tid=1605925]: |
156ms |
44ms |
| others: | 245ms |
| total: | 500ms |
