вложенная ХП, возвращающая курсор (nested SP that return cursor)
классика : DB2 UDB EEE 7.2 FP 10A SERVICE LEVEL WR21331 ХП 1: CREATE PROCEDURE DATASCHEMA.MYSP1 () RESULT SETS 1 LANGUAGE SQL BEGIN ... DECLARE my_cursor CURSOR WITH RETURN FOR мой запросишко ; ... OPEN my_cursor ; END ХП 2: CREATE PROCEDURE DATASCHEMA.MYSP2 () LANGUAGE SQL BEGIN ... DECLARE var_not_found SMALLINT DEFAULT 0 ; DECLARE mynested RESULT_SET_LOCATOR VARYING ; DECLARE CONTINUE HANDLER FOR NOT FOUND -- SQLSTATE '02000' SET var_not_found = 1 ; ... CALL SPGETBDAYMAP () ; ASSOCIATE RESULT SET LOCATOR (mynested) WITH PROCEDURE SPGETBDAYMAP; ALLOCATE nestedsp_cursor CURSOR FOR RESULT SET mynested ; fetch_loop : -- вычитываем курсор nestedsp_cursor END LOOP fetch_loop ; CLOSE nestedsp_cursor ; END ; !!! вызов CALL SPGETBDAYMAP (par_business_day, call_code, call_state) ; влечет WARNING : SQLSTATE=0100E/SQLCODE=464 КОТОРЫЙ ПРИХОДИТЬСЯ ИГНОРИРОВАТЬ И ВСЕ ЛАДУШКИ ОТРАБАТЫВАЕТ, НО ОТКЕЛЯ ОН ??????????? ЭТОТ WARNING ЧИТАЕМ ПАПИРУС : SQL0464W Procedure “<procedure-name>” returned “<generated-nbrresults>” query result sets, which exceeds the defined limit “<max-nbr-results>”. Explanation: The stored procedure named by “<procedure-name>” completed normally. However, the stored procedure exceeded the defined limit on the number of query result sets the procedure can return. generated-nbr-results identifies the number of query result sets returned by the stored procedure. max-nbr-results identifies the defined limit on the number of query result sets for the stored procedure. Only the first “<max-nbr-results>” query result sets are returned to the SQL program that issued the SQL CALL statement. The possible causes are as follows: The stored procedure is unable to return “<generated-nbr-results>” result sets due to the DRDA limitations imposed by the client. The DRDA client establishes this limit with the MAXRSLCNT DDM code point. User Response: The SQL statement is successful. The SQLWARN9 field is set to ’Z’. sqlcode: +464 sqlstate: 0100E МОЖЕТ КТО СТАЛКИВАЛСЯ С ДАННОЙ СИТУАЦИЕЙ? СПАСИБО!! ... |
| 01.11.2005, 17:07 |
start [/forum/topic.php?desktop=1&fid=43&tid=1605707]: |
27ms |
35ms |
| others: | 267ms |
| total: | 371ms |
