логич.операции в дб2
будет ли в выражении (sql-процедура): Код: plaintext 1. 2. т.е. в случае (ParentCode IS NULL) == True будет ли проверяться (Trim(ParentCode)='') и если да, будет ли генериться исключение (сравнение const с NULL)? спасибо. ... |
| 30.06.2006, 14:02 |
Будет. Сравните: Код: plaintext 1. 2. 3. 4. 5. 6. 7. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. ... |
| 30.06.2006, 15:27 |
подскажите, пожалуйста, использование в STP Код: plaintext Код: plaintext 1. ... |
| 20.07.2006, 18:32 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. condition-information Specifies that the error or warning information for the previously executed SQL statement is to be returned. If information about an error is needed, the GET DIAGNOSTICS statement must be the first statement specified in the handler that will handle the error. If information about a warning is needed, and if the handler will get control of the warning condition, the GET DIAGNOSTICS statement must be the first statement specified in that handler. If the handler will not get control of the warning condition, the GET DIAGNOSTICS statement must be the next statement executed. This option can only be specified in the context of an SQL Procedure (SQLSTATE 42601). MESSAGE_TEXT Identifies any error or warning message text returned from the previously executed SQL statement. The message text is returned in the language of the database server where the statement is processed. If the statement completed with an SQLCODE of zero, an empty string is returned for a VARCHAR variable or blanks are returned for a CHAR variable. DB2_TOKEN_STRING Identifies any error or warning message tokens returned from the previously executed SQL statement. If the statement completed with an SQLCODE of zero, or if the SQLCODE had no tokens, an empty string is returned for a VARCHAR variable or blanks are returned for a CHAR variable. ... |
| 20.07.2006, 18:53 |
у меня и используется в SQL-процедуре: Код: plaintext 1. 2. первым statement - ом в обработчике ... |
| 20.07.2006, 19:04 |
start [/forum/topic.php?desktop=1&fid=43&tid=1605225]: |
47ms |
45ms |
| others: | 227ms |
| total: | 364ms |
