help!!!!!!!!!
Чего за.....? При перзагрузке сервера (Win2003 DB2.8.1.9) в db2diag.log вываливает... 2007-01-10-10.24.36.015000+180 I177992H407 LEVEL: Warning PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, recovery manager, sqlprecm, probe:2000 MESSAGE : Using parallel recovery with 5 agents 16 QSets 64 queues and 16 chunks 2007-01-10-10.26.39.171000+180 I178401H437 LEVEL: Warning PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, recovery manager, sqlprecm, probe:4000 MESSAGE : DIA2051W Forward phase of crash recovery has completed. Next LSN is "000000FA1DED09D5". 2007-01-10-10.26.39.171000+180 I178840H522 LEVEL: Error PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, data protection, sqlptudo, probe:3890 MESSAGE : LogHeader: DATA #1 : Hexdump, 32 bytes 0x544D89F8 : 0000 0000 4100 0002 0000 0000 0000 0000 ....A........... 0x544D8A08 : 2030 B592 A86A DE6C DF7A 6410 0000 0000 0...j.l.zd..... 2007-01-10-10.26.39.171000+180 I179364H343 LEVEL: Error PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, data protection, sqlptudo, probe:3890 MESSAGE : LogData: 2007-01-10-10.26.39.171000+180 I179709H506 LEVEL: Error PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, data protection, sqlptudo, probe:3720 RETCODE : ZRC=0x87100027=-2028994521=SQLP_TRECTYPERR "A record other than those expected has been read during abort" DIA8536C A bad record type was encountered. 2007-01-10-10.26.39.171000+180 I180217H448 LEVEL: Warning PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, data protection, sqlptudo, probe:4350 MESSAGE : LSN being undone: DATA #1 : Hexdump, 8 bytes 0x0228A958 : 0000 00FA 0D88 8EF6 ........ 2007-01-10-10.26.39.171000+180 I180667H162 LEVEL: Error PID:1676 TID:3960 NODE:000 Title: SQLP_TENTRY Dump File:C:\PROGRA~1\IBM\SQLLIB\DB2\16763960.000 2007-01-10-10.26.39.171000+180 I180831H171 LEVEL: Error PID:1676 TID:3960 NODE:000 Title: SQLE_AGENT_PRIVATECB Dump File:C:\PROGRA~1\IBM\SQLLIB\DB2\16763960.000 2007-01-10-10.26.39.171000+180 I181004H160 LEVEL: Error PID:1676 TID:3960 NODE:000 Title: SQLP_DBCB Dump File:C:\PROGRA~1\IBM\SQLLIB\DB2\16763960.000 2007-01-10-10.26.39.171000+180 I181166H159 LEVEL: Error PID:1676 TID:3960 NODE:000 Title: SQLP_ACB Dump File:C:\PROGRA~1\IBM\SQLLIB\DB2\16763960.000 2007-01-10-10.26.39.171000+180 I181327H505 LEVEL: Error PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, recovery manager, sqlprudm, probe:40 RETCODE : ZRC=0x87100027=-2028994521=SQLP_TRECTYPERR "A record other than those expected has been read during abort" DIA8536C A bad record type was encountered. 2007-01-10-10.26.39.171000+180 I181834H495 LEVEL: Error PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, recovery manager, sqlpresr, probe:640 DATA #1 : String, 142 bytes Crash recovery failed with rc -2028994521 LowtranLSN 000000FA0D830799 MinbuffLSN 000000FA11A2AB0E Recovery started on log file S0007250.LOG. 2007-01-10-10.26.39.171000+180 I182331H433 LEVEL: Severe PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, base sys utilities, recover, probe:16 MESSAGE : DiagData DATA #1 : Hexdump, 4 bytes 0x544D9514 : 2700 1087 '... 2007-01-10-10.26.39.171000+180 I182766H412 LEVEL: Error PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, base sys utilities, recover, probe:16 DATA #1 : Hexdump, 4 bytes 0x544D9514 : 2700 1087 '... 2007-01-10-10.26.39.187000+180 E183180H391 LEVEL: Error PID : 1676 TID : 3960 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MY_BASE APPHDL : 0-678 APPID: C0A82DE5.ID06.00E300070203 FUNCTION: DB2 UDB, base sys utilities, recover, probe:60 MESSAGE : ADM1532E Crash recovery has failed with SQLCODE "-1042". Это конец? ... |
| 10.01.2007, 10:27 |
start [/forum/topic.php?desktop=1&fid=43&tid=1604879]: |
79ms |
44ms |
| others: | 259ms |
| total: | 432ms |
