COMMIT
Где можно почитать о COMMIT при репликации выдает ошибку об переполнении файла репликации где тут можно добавить COMMIT , чтобы не переполнялся файл: db2 connect to *** user **** using **** db2 import from C:\1\MMDOC.MMMS.DEL of del insert into ARCMMDOC.AMMS db2 terminate Заранее благодарю! ... |
| 19.01.2007, 12:36 |
COMMIT
db2 => ? import IMPORT FROM filename OF {IXF | ASC | DEL | WSF} [LOBS FROM lob-path [ {,lob-path} ... ] ] [MODIFIED BY filetype-mod ...] [METHOD {L ( col-start col-end [ {,col-start col-end} ... ] ) [NULL INDICATORS (col-position [ {,col-position} ... ] )] | N ( col-name [ {,col-name} ... ] ) | P ( col-position [ {,col-position} ... ] )}] [ALLOW {NO | WRITE} ACCESS] [COMMITCOUNT {n | AUTOMATIC}] [{RESTARTCOUNT | SKIPCOUNT} n] [ROWCOUNT n] [WARNINGCOUNT n] [NOTIMEOUT] [MESSAGES message-file] {{INSERT | INSERT_UPDATE | REPLACE | REPLACE_CREATE} INTO {table-name [( insert-column , ... )] | hierarchy-description} | CREATE INTO {table-name [( insert-column , ... )] | hierarchy-description {AS ROOT TABLE | UNDER sub-table-name} [IN tablespace-name [INDEX IN tablespace-name] [LONG IN tablespace-name]]} [datalink-specification] filetype-mod: COMPOUND=x, INDEXSCHEMA=schema, FORCEIN, INDEXIXF, IMPLIEDDECIMAL, NOCHECKLENGTHS, NOEOFCHAR, NULLINDCHAR, RECLEN=x, STRIPTBLANKS, STRIPTNULLS, NO_TYPE_ID, NODOUBLEDEL, LOBSINFILE, USEDEFAULTS, CHARDELx, COLDELx, DLDELx, DECPLUSBLANK, DECPTx, DATESISO, DELPRIORITYCHAR, IDENTITYMISSING, IDENTITYIGNORE, GENERATEDMISSING, GENERATEDIGNORE, DATEFORMAT=x, TIMEFORMAT=x, TIMESTAMPFORMAT=x, KEEPBLANKS, CODEPAGE=x, NOROWWARNINGS, NOCHARDEL, USEGRAPHICCODEPAGE hierarchy-description: {ALL TABLES | (sub-table-name [(insert-column, ...)], ...)} [IN] HIERARCHY {STARTING sub-table-name | (sub-table-name, ...)} datalink-specification: ([DL_LINKTYPE URL][{DL_URL_REPLACE_PREFIX prefix | DL_URL_DEFAULT_PREFIX prefix}] [DL_URL_SUFFIX suffix], ...) db2 => ... |
| 19.01.2007, 12:40 |
start [/forum/topic.php?desktop=1&fid=43&tid=1604863]: |
48ms |
41ms |
| others: | 256ms |
| total: | 385ms |
