fetch first clause within subquery?
How can I implement the following: Код: plaintext 1. 2. 3. 4. 5. 6. 7. Thanks in advance. ... |
| 02.04.2007, 16:57 |
Sorry. OS/400 v5r3 ... |
| 02.04.2007, 16:58 |
AFAIK there is no easy solution for this task in V5R3. You can: 1. wrap subselect into external udf. 2. write sql udf where for each row from table1 you will select name from table2 for corresponding id into local variable and then insert this value into some temporary table. Finally you can return select from this temporary table. ... |
| 02.04.2007, 18:36 |
Another way is to wrap scalar subselect into sql scalar udf: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. ... |
| 03.04.2007, 10:17 |
start [/forum/topic.php?desktop=1&fid=43&tid=1604693]: |
92ms |
46ms |
| others: | 271ms |
| total: | 467ms |
