Как посмотреть список lock'ов? (-)
| 26.10.2007, 07:01 |
select * from table( SNAP_GET_LOCK (cast(null as varchar(1)), -1)) t ... |
| 26.10.2007, 09:53 |
Ругается зараза :( DB2 v8.2 ------------------------------ Commands Entered ------------------------------ select * from table(SNAP_GET_LOCK(cast(null as varchar(1)), -1)) t; ------------------------------------------------------------------------------ select * from table(SNAP_GET_LOCK(cast(null as varchar(1)), -1)) t SQL0440N No authorized routine named "SNAP_GET_LOCK" of type "FUNCTION" having compatible arguments was found. SQLSTATE=42884 SQL0440N No authorized routine named "SNAP_GET_LOCK" of type "FUNCTION " having compatible arguments was found. Explanation: This occurs in a reference to routine "<routine-name>", when the database manager cannot find a routine it can use to implement the reference. There are several reasons why this could occur: o "<routine-name>" was either incorrectly specified or does not exist in the database. o A qualified reference was made, and the qualifier was incorrectly specified. o The user's SQL path does not contain the schema to which the desired function or method belongs, and an unqualified reference was used. o The wrong number of arguments were included. o The right number of arguments were included in the function or method reference, but the data types of one or more of the arguments is incorrect. o The routine does not exist in the database with the same function id that was used when the package was bound (applies to static statements). o The mutator method corresponding to an attribute assignment used in an UPDATE statement could not be found. The data type of the new value for the attribute is not a data type that is the same or promotable to the data type of the attribute. o The routine invoker is not authorized to execute the routine. User Response: Fix the problem and retry. This could involve catalog access, a change to the statement, a grant of the execute privilege to the routine invoker, the addition of new functions, and/or a change to the SQL path. sqlcode : -440 sqlstate : 42884 ... |
| 26.10.2007, 12:04 |
select * from table( SNAPSHOT_LOCK (cast(null as varchar(1)), -1)) t ... |
| 26.10.2007, 12:19 |
Спасибо! заработало. ... |
| 26.10.2007, 12:21 |
Подскажите, плз, как выяснить IP адрес хоста, который залокал эти таблицы. ... |
| 26.10.2007, 13:52 |
indicatrixПодскажите, плз, как выяснить IP адрес хоста, который залокал эти таблицы. select a. appl_id from table(SNAPSHOT_LOCK(cast(null as varchar(1)), -1)) l join table(SNAPSHOT_APPL_INFO(cast(null as varchar(1)), -1)) a on l.agent_id=a.agent_id ... |
| 26.10.2007, 14:36 |
Отлично! То что нужно! Огромное спасибо!!! ... |
| 26.10.2007, 14:48 |
Добрый день! Запускаю: Код: plaintext 1. 2. 3. таблиц (SYSSECTION, SYSPLANDEP, SYSPLAN), в остальных записях это поле пустое. А зависание происходит запроса, который построен на пользовательских таблицах, которых в списке локов нет. Как можно мне определить кто, каким запросом или какая таблицы залочена? Заранее спасибо! ... |
| 27.10.2007, 09:26 |
Что вы подразумеваете под выражением indicatrixзависание запроса Выполнение запроса после некоторого времени ожидания прекращается с ошибкой? Из-за истечения времени ожидания установки локов или у вас deadlock? ... |
| 27.10.2007, 12:40 |
Зависает выполнение следующей хранимки: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. С удаленных машин в это время выполняются запросы, которые не обращаются к таблице TBL, поэтому я хочу выяснить какой процесс, какой запрос заблокировал селект из этой таблицы. ... |
| 27.10.2007, 13:11 |
start [/forum/topic.php?desktop=1&fid=43&tid=1604246]: |
51ms |
42ms |
| others: | 232ms |
| total: | 362ms |
