Ошибка при запуске control center на AIX
Привет всем! DB2 v8 FP12, AIX 5.3., bos.rte.libc 5.3.0.40. Есть небольшая проблема. При запуске DB2 control center for AIX он запускается, но в diag.log выдается ошибка. 2007-12-11-10.55.03.037689-240 I1A244 LEVEL: Error PID : 340194 TID : 1 FUNCTION: DB2 Common, OSSe, OSSHLibrary::load, probe:60 MESSAGE : ECF=0x90000076 Cannot load the specified library DATA #1 : Hex, 4 bytes 0x2 2007-12-11-10.55.03.048173-240 I246A353 LEVEL: Error PID : 340194 TID : 1 FUNCTION: DB2 Common, OSSe, OSSHLibrary::load, probe:70 MESSAGE : ECF=0x90000076 Cannot load the specified library DATA #1 : String, 107 bytes 0509-022 Cannot load module . 0509-026 System error: A file or directory in the path name does not exist. 2007-12-11-10.55.03.048252-240 I600A283 LEVEL: Error PID : 340194 TID : 1 FUNCTION: DB2 Common, OSSe, OSSHLibrary::load, probe:80 MESSAGE : ECF=0x90000076 Cannot load the specified library DATA #1 : Hex, 4 bytes 0x2 DATA #2 : String, 11 bytes libdddjni.a 2007-12-11-10.55.03.049575-240 I884A361 LEVEL: Error PID : 340194 TID : 1 FUNCTION: DB2 Common, OSSe, OSSHLibrary::load, probe:90 MESSAGE : ECF=0x90000076 Cannot load the specified library DATA #1 : String, 115 bytes 0509-022 Cannot load module shr_64.o. 0509-026 System error: A file or directory in the path name does not exist. 2005-12-11-10.55.03.622991-240 I1246A244 LEVEL: Error PID : 340194 TID : 1 FUNCTION: DB2 Common, OSSe, OSSHLibrary::load, probe:60 MESSAGE : ECF=0x90000076 Cannot load the specified library DATA #1 : Hex, 4 bytes 0x2 2005-12-11-10.55.03.623087-240 I1491A353 LEVEL: Error PID : 340194 TID : 1 FUNCTION: DB2 Common, OSSe, OSSHLibrary::load, probe:70 MESSAGE : ECF=0x90000076 Cannot load the specified library DATA #1 : String, 107 bytes 0509-022 Cannot load module . 0509-026 System error: A file or directory in the path name does not exist. 2005-12-11-10.55.03.623153-240 I1845A283 LEVEL: Error PID : 340194 TID : 1 FUNCTION: DB2 Common, OSSe, OSSHLibrary::load, probe:80 MESSAGE : ECF=0x90000076 Cannot load the specified library DATA #1 : Hex, 4 bytes 0x2 DATA #2 : String, 11 bytes libdddjni.a 2005-12-11-10.55.03.624472-240 I2129A361 LEVEL: Error PID : 340194 TID : 1 FUNCTION: DB2 Common, OSSe, OSSHLibrary::load, probe:90 MESSAGE : ECF=0x90000076 Cannot load the specified library DATA #1 : String, 115 bytes 0509-022 Cannot load module shr_64.o. 0509-026 System error: A file or directory in the path name does not exist. ... |
| 12.12.2007, 15:01 |
Зачем он тебе на AIX пользуй для него windows. ... |
| 12.12.2007, 15:51 |
Так и делаем.А все же? ... |
| 12.12.2007, 16:04 |
Привет, Олег! а что у тебя в ls -la /usr/lib | grep -i db2 ? P.S.: А в v9 больше нет жабовской графики на aix. И не будет. ... |
| 13.12.2007, 11:06 |
это же обычные. нужно смотреть на переменные среды LIBPATH и LD_LIBRARY_PATH (вроде так). а чтобы их установить должен быть profile в директории instance owner-a и еще find / -name shr_64.o find / -name libdddjni.a ... |
| 13.12.2007, 11:17 |
Привет Марк. ls -la /usr/lib | grep -i db2 lrwxrwxrwx 1 root system 31 Jul 20 2006 libdb2.a -> /usr/opt/db 2_08_01/lib/libdb2.a К сожалению перейти на DB2 v9 не получится. библиотек libdddjni.a и shr_64.o нет. Может кто знает в какой они fileset входят? ... |
| 13.12.2007, 16:51 |
Сделай ради эксперимента libdb2.a -> /usr/opt/db 2_08_01/lib64/libdb2.a ... |
| 13.12.2007, 18:36 |
Попробовал. Такая же ошибка. ... |
| 14.12.2007, 13:27 |
Еще запустить db2ln можно. ... |
| 14.12.2007, 16:54 |
start [/forum/topic.php?desktop=1&fid=43&tid=1604144]: |
67ms |
52ms |
| others: | 222ms |
| total: | 391ms |
