This three-part demo series shows you how to install the IBM Mashup Starter Kit.
This three-part demo series shows you how to install the IBM® Mashup Starter Kit. Part 1 shows you how to check the prerequisites, install DB2® Express-C and Zend Core for IBM, if necessary, and create the DB2 databases. http://www.ibm.com/developerworks/offers/lp/demos/summary/installmsk1.html?S_TACT=105AGX58&S_CMP=DEMO&ca=dnl-3801demo3 Part 2 shows you how to configure the php.ini, fastcgi.conf, and httpd.conf files. You will also see how the Apache Server is restarted http://www.ibm.com/developerworks/offers/lp/demos/summary/installmsk2.html?S_TACT=105AGX58&S_CMP=DEMO&ca=dnl-3801demo4 Part 3 shows you how to install QEDWiki and the Mashup Hub. http://www.ibm.com/developerworks/offers/lp/demos/summary/installmsk3.html?S_TACT=105AGX58&S_CMP=DEMO&ca=dnl-3801demo5 С уважением, Вадим. ... |
| 28.01.2008, 19:18 |
start [/forum/topic.php?desktop=1&fid=43&tid=1604084]: |
43ms |
33ms |
| others: | 245ms |
| total: | 372ms |
