CloudSpace->DB2
Доброго времени суток , форумчане ! Пытаюсь провести миграцию WSPortal на DB2 , Переконфигурировал , пытаюсь запустить создание БД : WPSconfig create-local-database-db2 Выходит ошибка : action-create-database: Mon Feb 25 15:10:05 BDT 2008 action-create-db-mp: Mon Feb 25 15:10:06 BDT 2008 [echo] Trying to create database for dbdomain 'release' on 'db2' [sqlproc] action: exist-database [sqlproc] _________________________________________________________ [sqlproc] DbDomain: release [sqlproc] Could not connect to database [sqlproc] com.ibm.db2.jcc.b.DisconnectException: The application server rejected establishment of the connection. An attempt was made to access a database, wpsdb, which was not found. DB2ConnectionCorrelator: null [sqlproc] at com.ibm.db2.jcc.c.hb.u(hb.java:1642) [sqlproc] at com.ibm.db2.jcc.c.hb.n(hb.java:533) [sqlproc] at com.ibm.db2.jcc.c.hb.a(hb.java:343) [sqlproc] at com.ibm.db2.jcc.c.hb.a(hb.java:115) [sqlproc] at com.ibm.db2.jcc.c.b.e(b.java:1394) [sqlproc] at com.ibm.db2.jcc.c.b.b(b.java:1268) [sqlproc] at com.ibm.db2.jcc.c.b.s(b.java:1040) [sqlproc] at com.ibm.db2.jcc.c.b.b(b.java:748) [sqlproc] at com.ibm.db2.jcc.c.b.a(b.java:734) [sqlproc] at com.ibm.db2.jcc.c.b.<init>(b.java:335) [sqlproc] at com.ibm.db2.jcc.DB2Driver.connect(DB2Driver.java:165) [sqlproc] at com.ibm.wps.config.SqlProcessor.process(Unknown Source) [sqlproc] at com.ibm.wps.config.SqlProcessor.process(Unknown Source) [sqlproc] at com.ibm.wps.config.SqlProcessorTask.validateDbExist(Unknown Source) [sqlproc] at com.ibm.wps.config.SqlProcessorTask.execute(Unknown Source) [sqlproc] at org.apache.tools.ant.Task.perform(Task.java:341) [sqlproc] at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:117) [sqlproc] at com.ibm.wps.config.If.execute(Unknown Source) [sqlproc] at org.apache.tools.ant.Task.perform(Task.java:341) [sqlproc] at org.apache.tools.ant.Target.execute(Target.java:309) [sqlproc] at org.apache.tools.ant.Target.performTasks(Target.java:336) [sqlproc] at org.apache.tools.ant.Project.executeTarget(Project.java:1339) [sqlproc] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:397) [sqlproc] at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:143) [sqlproc] at org.apache.tools.ant.Task.perform(Task.java:341) [sqlproc] at com.ibm.wps.config.ForTask.execute(Unknown Source) [sqlproc] at org.apache.tools.ant.Task.perform(Task.java:341) [sqlproc] at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:117) [sqlproc] at com.ibm.wps.config.If.execute(Unknown Source) [sqlproc] at org.apache.tools.ant.Task.perform(Task.java:341) [sqlproc] at org.apache.tools.ant.Target.execute(Target.java:309) [sqlproc] at org.apache.tools.ant.Target.performTasks(Target.java:336) [sqlproc] at org.apache.tools.ant.Project.executeTarget(Project.java:1339) [sqlproc] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:397) [sqlproc] at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:143) [sqlproc] at org.apache.tools.ant.Task.perform(Task.java:341) [sqlproc] at org.apache.tools.ant.Target.execute(Target.java:309) [sqlproc] at org.apache.tools.ant.Target.performTasks(Target.java:336) [sqlproc] at org.apache.tools.ant.Project.executeTarget(Project.java:1339) [sqlproc] at org.apache.tools.ant.Project.executeTargets(Project.java:1255) [sqlproc] at org.apache.tools.ant.Main.runBuild(Main.java:609) [sqlproc] at org.apache.tools.ant.Main.start(Main.java:196) [sqlproc] at com.ibm.wps.config.WpsConfigMain.process(Unknown Source) [sqlproc] at com.ibm.wps.config.WpsConfigMain.main(Unknown Source) [sqlproc] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [sqlproc] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:85) [sqlproc] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:58) [sqlproc] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:60) [sqlproc] at java.lang.reflect.Method.invoke(Method.java:391) [sqlproc] at com.ibm.ws.bootstrap.WSLauncher.run(WSLauncher.java:219) [sqlproc] at java.lang.Thread.run(Thread.java:570) [sqlproc] (ErrCode=-4499, SqlState=08004) [sqlproc] _________________________________________________________ BUILD FAILED file:../config/actions/db_cfg.xml:140: ERROR: Error while checking database existance... Total time: 28 seconds Вроде должен создавать а не создает =( Ктонибудь встречался ? УРЛ к ДБ : release.DbUrl=jdbc:db2://127.0.0.1:50000/wpsdb:returnAlias=0; Заранее благодарен. ... |
| 25.02.2008, 13:04 |
start [/forum/topic.php?desktop=1&fid=43&tid=1604031]: |
| others: | 221ms |
| total: | 281ms |
