backup db2 в linux
Помогите разобраться в чем дело есть скрипт вот его содержимое #!/bin/bash #VERSION=1.04 PATH=$PATH:/opt/IBM/db2/V8.1/bin ### variables ### BACKUP_SCTRH=$( cat < /script/cfg/backup.cfg ) if [ -z "$BACKUP_SCTRH" ] then BACKUP_SCTRH="/tmp" fi # save old backups (days) ZZZ=28 case $( date +%u ) in 1) echo "" > /script/cfg/mon su db2inst -c "db2 force application all" su db2inst -c "db2 backup database SCTRH to $BACKUP_SCTRH" | grep -o -e "[0-9]\{14\}" > /script/cfg/mon cp -f /home/db2inst/SCTRH/db2inst/NODE0000/SQL00001/db2rhist.asc /script/cfg/db2rhist.asc if [ $(cat < /script/cfg/mon) != "" ] then ##### deleting incrementals backups cd $BACKUP_SCTRH echo '#!/bin/bash cd '$BACKUP_SCTRH > /script/cfg/delete_old_backup.sh ls -1tl | grep -e "SCTRH.*\.001$" | awk -v ZAP=$ZZZ '{ if ( NR > ZAP ) print "rm " $0}' >> /script/cfg/delete_old_backup.sh chmod 777 /script/cfg/delete_old_backup.sh /script/cfg/delete_old_backup.sh echo "" > /script/cfg/tue > /script/cfg/wed > /script/cfg/thu > /script/cfg/fri > /script/cfg/sat > /script/cfg/sun > /dev/null fi ;; 2) echo "" > /script/cfg/tue su db2inst -c "db2 backup database SCTRH online incremental delta to $BACKUP_SCTRH" | grep -o -e "[0-9]\{14\}" > /script/cfg/tue echo "" >> /script/cfg/tue cp -f /home/db2inst/SCTRH/db2inst/NODE0000/SQL00001/db2rhist.asc /script/cfg/db2rhist.asc ;; 3) echo "" > /script/cfg/wed su db2inst -c "db2 backup database SCTRH online incremental delta to $BACKUP_SCTRH" | grep -o -e "[0-9]\{14\}" > /script/cfg/wed echo "" >> /script/cfg/wed cp -f /home/db2inst/SCTRH/db2inst/NODE0000/SQL00001/db2rhist.asc /script/cfg/db2rhist.asc ;; 4) echo "" > /script/cfg/thu su db2inst -c "db2 backup database SCTRH online incremental delta to $BACKUP_SCTRH" | grep -o -e "[0-9]\{14\}" > /script/cfg/thu echo "" >> /script/cfg/thu cp -f /home/db2inst/SCTRH/db2inst/NODE0000/SQL00001/db2rhist.asc /script/cfg/db2rhist.asc ;; 5) echo "" > /script/cfg/fri su db2inst -c "db2 backup database SCTRH online incremental delta to $BACKUP_SCTRH" | grep -o -e "[0-9]\{14\}" > /script/cfg/fri echo "" >> /script/cfg/fri cp -f /home/db2inst/SCTRH/db2inst/NODE0000/SQL00001/db2rhist.asc /script/cfg/db2rhist.asc ;; 6) echo "" > /script/cfg/sat su db2inst -c "db2 backup database SCTRH online incremental delta to $BACKUP_SCTRH" | grep -o -e "[0-9]\{14\}" > /script/cfg/sat echo "" >> /script/cfg/sat cp -f /home/db2inst/SCTRH/db2inst/NODE0000/SQL00001/db2rhist.asc /script/cfg/db2rhist.asc ;; 7) echo "" > /script/cfg/sun su db2inst -c "db2 backup database SCTRH online incremental delta to $BACKUP_SCTRH" | grep -o -e "[0-9]\{14\}" > /script/cfg/sun echo "" >> /script/cfg/sun cp -f /home/db2inst/SCTRH/db2inst/NODE0000/SQL00001/db2rhist.asc /script/cfg/db2rhist.asc ;; esac Прописываю его запуск в crontab echo "0 15 * * * root /script/cfg/backup.sh >> /script/cfg/backup.log 2>&1" >> /etc/crontab ждем время итог все пусто даже log пустой что еще нужно прописать и где это сделать Да кстати запускаю в терминале backup.sh все проходит на ура все операции провожу rootОМ ... |
| 05.07.2007, 09:47 |
backup db2 в linux
Разобрался уже давно вот увидел решил рассказать может кому пригодиться вообщем в крон необходимо добавить переменные LANG="ru_RU.UTF-8" SUPPORTED="ru_RU.UTF-8:ru_RU:ru" саму кодировку выставляем в соответствии с кодировкой базы. и на всякий случай добавляю строку в backup.sh . /home/db2inst/sqllib/db2profile чтобы все пути были видны и rootу тоже. ... |
| 27.05.2008, 10:25 |
start [/forum/topic.php?desktop=1&fid=43&tid=1603860]: |
38ms |
33ms |
| others: | 211ms |
| total: | 318ms |
