LOCKlIST и MAXLOCKS
Добрый день! Инфа по блокировке пишется в LOCKLIST у которого есть максимальный размер... Подскажите, плз, сколько занимает запись об одной блокировке в байтах? Хотя бы примерно? Сорри, за дурацкий вопрос :) Заранее пасиба! ... |
| 18.07.2008, 18:28 |
LOCKlIST и MAXLOCKS
Как обычно, в мануале все написано: On 32-bit platforms, each lock requires 40 or 80 bytes of the lock list, depending on whether other locks are held on the object: * 80 bytes are required to hold a lock on an object that has no other locks held on it * 40 bytes are required to record a lock on an object that has an existing lock held on it. On 64-bit platforms, each lock requires 64 or 128 bytes of the lock list, depending on whether other locks are held on the object: * 128 bytes are required to hold a lock on an object that has no other locks held on it * 64 bytes are required to record a lock on an object that has an existing lock held on it. ... |
| 19.07.2008, 00:19 |
start [/forum/topic.php?desktop=1&fid=43&tid=1603781]: |
60ms |
47ms |
| others: | 216ms |
| total: | 369ms |
