откройте пожалуйста PMR кто может
1. книжка DB2 10 for z/OS Installation and Migration Guide GC19-2974-01 Chapter 2. Preparing your system to install or migrate DB2 страница 74 --------------- Some BIND PLAN and REBIND PLAN command options are no longer supported The ACQUIRE(ALLOCATE) option of the BIND PLAN and REBIND PLAN commands is no longer supported. If you specify ACQUIRE(ALLOCATE), DB2 issues a warning message and uses ACQUIRE(USE). Also, the MEMBER option of BIND PLAN and REBIND PLAN is no longer supported. If you specify MEMBER, DB2 issues a warning message, binds the specified DBRM into a package, and binds the package into a plan. ---------------- 2. книжка DB2 10 for z/OS Command Reference SC19-2972-01 команда BIND PLAN там опция MEMBER есть --- BIND PLAN(IMSONLY) - MEMBER(DSN8BC81) - ACTION(ADD) - ISOLATION(CS) - OWNER(DEPTM92) - QUALIFIER(PRODUCTN) - CACHESIZE - ENABLE(IMS) -- ... |
| 18.03.2011, 13:47 |
start [/forum/topic.php?desktop=1&fid=43&tid=1602340]: |
59ms |
49ms |
| others: | 226ms |
| total: | 383ms |
