db2setup падает, не начавшись [db2setup 9.7.0 AIX 6.1]
Добрый день. Падает установка Db2 9.7 на AIX, при старте самого установщика (показывается лого и потом исчезает). В /tmp/db2setup.err пишется: Unhandled exception Type=Segmentation error vmState=0x00000000 J9Generic_Signal_Number=00000004 Signal_Number=0000000b Error_Value=00000000 Signal_Code=00000033 Handler1=09001000A03CDCD0 Handler2=09001000A03C5A40 R0=00000001104882B0 R1=0000000112962C20 R2=09001000A043AC20 R3=0000000000000002 R4=0700000000DEFF78 R5=0000000112728FF8 R6=0000000112728F30 R7=0000000112728F30 R8=0000000000000028 R9=0000000112728FF8 R10=0700000000DDDF00 R11=0900000000BA508C R12=09000000008757F4 R13=000000011296B800 R14=0000000112728FF8 R15=000000011270F600 R16=0000000110CB0C30 R17=0000000111BC4CC8 R18=09001000A03D1D30 R19=000000000000000F R20=0000000111810E98 R21=0000000112729068 R22=000000011270F6A0 R23=0000000000000000 R24=09001000A03C7920 R25=000000000000007E R26=0000000112606DA0 R27=0000000110149E70 R28=0000000000000000 R29=09001000A03CDCB8 R30=0000000111810C70 R31=0700000000DEFF38 IAR=0900000000BA508C LR=00000001104882CC MSR=A00000000000D032 CTR=0900000000BA508C CR=4800028420000007 FPSCR=8200000000000000 XER=2000000782000000 FPR0 000000c0000000c0 (f: 192.000000, d: 4.074232e-312) FPR1 41e0000000000000 (f: 0.000000, d: 2.147484e+09) FPR2 c1e0000000000000 (f: 0.000000, d: -2.147484e+09) FPR3 3fe8000000000000 (f: 0.000000, d: 7.500000e-01) FPR4 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR5 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR6 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR7 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR8 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR9 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR10 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR11 4070000000000000 (f: 0.000000, d: 2.560000e+02) FPR12 3fe8000000000000 (f: 0.000000, d: 7.500000e-01) FPR13 4068000000000000 (f: 0.000000, d: 1.920000e+02) FPR14 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR15 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR16 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR17 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR18 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR19 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR20 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR21 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR22 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR23 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR24 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR25 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR26 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR27 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR28 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR29 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR30 0000000000000000 (f: 0.000000, d: 0.000000e+00) FPR31 0000000000000000 (f: 0.000000, d: 0.000000e+00) Module=/tmp/db2.tmp.2621606/db2/aix/java/jre/lib/ppc64/libj9jit24.so Module_base_address=090000000094B000 Target=2_40_20071121_015015_BHdSMr (AIX 6.1) CPU=ppc64 (16 logical CPUs) (0x1de000000 RAM) ----------- Stack Backtrace ----------- /tmp/db2.tmp.2621606/db2/aix/java/jre/lib/ppc64/libj9vm24.so:0x008226DC [0x00815000 +0x0000D6DC] /tmp/db2.tmp.2621606/db2/aix/java/jre/lib/ppc64/libj9prt24.so:0x008AA0F4 [0x008A7000 +0x000030F4] /tmp/db2.tmp.2621606/db2/aix/java/jre/lib/ppc64/libj9vm24.so:0x008225F0 [0x00815000 +0x0000D5F0] /tmp/db2.tmp.2621606/db2/aix/java/jre/lib/ppc64/libj9thr24.so:0x008955F0 [0x00893000 +0x000025F0] /usr/lib/libpthreads.a:0x0078DD54 [0x0078A000 +0x00003D54] 0x00000000 --------------------------------------- JVMDUMP006I Processing Dump Event "gpf", detail "" - Please Wait. JVMDUMP007I JVM Requesting System Dump using '/tmp/db2.tmp.2621606/db2/aix/install/core.20110401.025327.8716516.0001.dmp' JVMDUMP010I System Dump written to /tmp/db2.tmp.2621606/db2/aix/install/core.20110401.025327.8716516.0001.dmp JVMDUMP007I JVM Requesting Snap Dump using '/tmp/db2.tmp.2621606/db2/aix/install/Snap.20110401.025327.8716516.0002.trc' JVMDUMP010I Snap Dump written to /tmp/db2.tmp.2621606/db2/aix/install/Snap.20110401.025327.8716516.0002.trc JVMDUMP007I JVM Requesting Java Dump using '/tmp/javacore.20110401.025327.8716516.0003.txt' JVMDUMP013I Processed Dump Event "gpf", detail "". Мой AIX: oslevel -s6100-05-02-1034 Если нужна более детальная информация - скажите - предоставлю. Спасибо! ... |
| 01.04.2011, 17:30 |
Добрый день. А если так перед установкой: export JAVA_COMPILER=NONE ? ... |
| 01.04.2011, 18:06 |
start [/forum/topic.php?desktop=1&fid=43&tid=1602315]: |
61ms |
49ms |
| others: | 225ms |
| total: | 382ms |
