IBM DB2 Merge Backup for Linux , UNIX and Windows helps you speed up DB2 backup processi
FYI ... IBM DB2 Merge Backup for Linux , UNIX and Windows helps you speed up DB2 backup processing - http://www-01.ibm.com/common/ssi/cgi-bin/ssialias?subtype=ca&infotype=an&appname=iSource&supplier=877&letternum=ENUSZP11-0266 Kind regards, Vadim Golovsky. ... |
| 03.05.2011, 13:00 |
start [/forum/topic.php?desktop=1&fid=43&tid=1602280]: |
43ms |
29ms |
| others: | 258ms |
| total: | 371ms |
