connect to DB2 from local client
всем доброго времени суток! поставил на одном сервере DB2 for LUW 9.7 FP3SAP Client хочу приконектиться к удаленной базе со своей клиентской машины через JDBC к удаленной базе цепляюсь а как приконнетиться из консольных утилит ? ... |
| 23.06.2011, 17:50 |
ctginst1, СПАСИБО к сожалению не нашел у клиента db2cmd ... ... |
| 24.06.2011, 10:11 |
jack_nsk, Здравствуйте. THE NEW DB2 CLIENT SETUP IN SAP SYSTEMS WITH DB2 FOR LINUX, UNIX, AND WINDOWS ... |
| 24.06.2011, 10:44 |
Mark Barinsteinjack_nsk, Здравствуйте. THE NEW DB2 CLIENT SETUP IN SAP SYSTEMS WITH DB2 FOR LINUX, UNIX, AND WINDOWS Марк, спасибо! как всегда точен! авторThe DB2 Client offers the most comprehensive set of DB2 client functionality. Besides support for handling database connections and the underlying network communication it contains graphical tools for configuration and administration of an DB2 database and support for developing applications which access the database by common APIs like ODBC, JDBC, OLE.DB, ADO.NET and the DB2 Call Level Interface (CLI). In DB2 V9.5 this client was renamed to 'IBM Data Server client'. The DB2 Runtime Client offers that part of the functionality of the DB2 client that is needed to run applications. It contains no administration and configuration tools besides the DB2 Command Line Processor (CLP). The client was renamed to 'IBM Data Server Runtime Client' in DB2 V9.5. The DB2 CLI Driver (sometimes also referred as 'Thin Client' or 'CTC Driver'), introduced with DB2 V9.1, provides runtime support for applications which use the ODBC or CLI API. It is not part of any of the other clients and must be installed separately. The DB2 CLP is also not part of the driver. As the name suggest, it is not considered as a 'real' client. The term 'Driver' here suggests that it can only be used by applications to access the database. Contrary to the other DB2 clients the DB2 CLI Driver can be installed on an NFS mounted file system or on a Windows share. The DB2 CLI Driver was renamed to 'IBM Data Server Driver for ODBC and CLI' in DB2 V9.5. The DB2 JDBC Driver is a 100% pure Java (Type 4) platform-independent Driver for JDBC and SQL with support for the JDBC 3.0 specification. A special JDBC Driver with support for JDBC 4.0 was added in DB2 V9.5. The JDBC Driver is part of every full DB2 Client and DB2 Runtime Client installation, but it can also be installed separately. Again the installation on a shared file system is possible. The JDBC Driver is called 'IBM Data Server Driver for JDBC and SQLJ' in DB2 V9.5. судя по установке у меня встали DB2 CLI Driver + DB2 JDBC Driver пытаюсь разобраться, как без создания каталога присоединиться к базе ... |
| 27.06.2011, 08:25 |
jack_nsk... судя по установке у меня встали DB2 CLI Driver + DB2 JDBC Driver пытаюсь разобраться, как без создания каталога присоединиться к базе Connecting to databases with the IBM Data Server Driver for ODBC and CLI ... |
| 27.06.2011, 09:39 |
Mark Barinsteinjack_nsk... судя по установке у меня встали DB2 CLI Driver + DB2 JDBC Driver пытаюсь разобраться, как без создания каталога присоединиться к базе Connecting to databases with the IBM Data Server Driver for ODBC and CLI Марк, спасибо! перечитал ещё и САПовские доки... делал разные попытки, после какой-то соединение с базой появилось... возможно, когда вместо имени хоста в db2cli.ini (Hostname) поставил IP-адрес ... |
| 27.06.2011, 15:33 |
start [/forum/topic.php?desktop=1&fid=43&tid=1602209]: |
58ms |
46ms |
| others: | 256ms |
| total: | 410ms |
