Проблема с восстановлением БД
Добрый день! Имеем: OSName: SunOS NodeName: trinidad Version: Generic_118558-39 Release: 5.9 Machine: sun4u DB21085I Instance "db2inst1" uses "64" bits and DB2 code release "SQL09058" with level identifier "06090107". Informational tokens are "DB2 v9.5.0.8", "s110603", "IP23267", and Fix Pack "8". Product is installed at "/opt/IBM/db2/V9.5". Выполняем: db2 RESTORE DATABASE asukp user .... using .... FROM /common/backup/db2 TAKEN AT 20111205152132 TO /common/database/db2/asukp INTO asukp NEWLOGPATH /common/database/db2/asukp/logs WITH 2 BUFFERS BUFFER 1024 PARALLELISM 1 WITHOUT PROMPTING Получаем: SQL0902C A system error (reason code = "") occurred. Subsequent SQL statements cannot be processed. SQLSTATE=58005 Вот выдержка из диаглога: 2011-12-06-10.28.26.595010+240 I42158A674 LEVEL: Warning PID : 22122 TID : 1 PROC : db2bp INSTANCE: db2inst1 NODE : 000 EDUID : 1 FUNCTION: DB2 UDB, Connection Manager, sqleUCgetDirInfo, probe:1012 DATA #1 : SQLCA, PD_DB2_TYPE_SQLCA, 136 bytes sqlcaid : SQLCA sqlcabc: 136 sqlcode: -1013 sqlerrml: 5 sqlerrmc: ASUKP sqlerrp : SQLEUCCM sqlerrd : (1) 0x00000000 (2) 0x00000000 (3) 0x00000000 (4) 0x00000000 (5) 0x00000000 (6) 0x00000000 sqlwarn : (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) sqlstate: 2011-12-06-10.28.26.854247+240 I42833A461 LEVEL: Event PID : 7413 TID : 15 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 APPHDL : 0-410 APPID: *LOCAL.db2inst1.111206055533 AUTHID : DB2INST1 EDUID : 15 EDUNAME: db2agent (instance) 0 FUNCTION: DB2 UDB, config/install, sqlfLogUpdateCfgParam, probe:20 CHANGE : CFG DB ASUKP: "Num_ioservers" From: "3" <automatic> To: "255" 2011-12-06-10.28.26.858398+240 I43295A454 LEVEL: Event PID : 7413 TID : 15 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 APPHDL : 0-410 APPID: *LOCAL.db2inst1.111206055533 AUTHID : DB2INST1 EDUID : 15 EDUNAME: db2agent (instance) 0 FUNCTION: DB2 UDB, config/install, sqlfLogUpdateCfgParam, probe:20 CHANGE : CFG DB ASUKP: "Util_heap_sz" From: "5000" To: "131072" 2011-12-06-10.28.26.877388+240 I43750A500 LEVEL: Event PID : 7413 TID : 69 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : ASUKP APPHDL : 0-425 APPID: *LOCAL.db2inst1.111206062827 AUTHID : DB2INST1 EDUID : 69 EDUNAME: db2agent (ASUKP) 0 FUNCTION: DB2 UDB, config/install, sqlfLogUpdateCfgParam, probe:20 CHANGE : CFG DB ASUKP : "Database_memory" From: "20" <automatic> To: "172640" <automatic> 2011-12-06-10.28.27.202684+240 E44251A538 LEVEL: Error (OS) PID : 7413 TID : 69 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : ASUKP APPHDL : 0-425 APPID: *LOCAL.db2inst1.111206062827 AUTHID : DB2INST1 EDUID : 69 EDUNAME: db2agent (ASUKP) 0 FUNCTION: DB2 UDB, oper system services, sqloCSemCreate, probe:1 MESSAGE : ZRC=0x8300001C=-2097151972 CALLED : OS, -, unspecified_system_function OSERR : ENOSPC (28) "No space left on device" 2011-12-06-10.28.27.204020+240 I44790A466 LEVEL: Severe PID : 7413 TID : 69 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : ASUKP APPHDL : 0-425 APPID: *LOCAL.db2inst1.111206062827 AUTHID : DB2INST1 EDUID : 69 EDUNAME: db2agent (ASUKP) 0 FUNCTION: DB2 UDB, buffer pool services, sqlbpfCreateQ, probe:5 DATA #1 : String, 35 bytes Error creating a counting semaphore 2011-12-06-10.28.27.204579+240 I45257A481 LEVEL: Severe PID : 7413 TID : 69 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : ASUKP APPHDL : 0-425 APPID: *LOCAL.db2inst1.111206062827 AUTHID : DB2INST1 EDUID : 69 EDUNAME: db2agent (ASUKP) 0 FUNCTION: DB2 UDB, buffer pool services, sqlbpfCreateQ, probe:4 MESSAGE : ZRC=0x870F0077=-2029059977=SQLO_CSEM_INVALID "invalid counting sem" Как бороться с этой бедой?:) ... |
| 06.12.2011, 10:57 |
chuk_and_gek, Здравствуйте. db2 не может создать семафор в системе. См. Modifying kernel parameters (Solaris Operating System) ... |
| 06.12.2011, 12:09 |
start [/forum/topic.php?desktop=1&fid=43&tid=1601999]: |
57ms |
39ms |
| others: | 267ms |
| total: | 408ms |
