Health indicator "Database Heap Utilization" ("db.db_heap_util")
Добрый день! Имеем: SLES11 (x64), DB2 9.5 Ошибка 2011-12-13-19.41.15.325845+240 E116587827E1308 LEVEL: Error PID : 4029 TID : 140480429472080PROC : db2acd 0 INSTANCE: db2inst1 NODE : 000 FUNCTION: DB2 UDB, Health Monitor, HealthIndicator::update, probe:500 MESSAGE : ADM10500E Health indicator "Database Heap Utilization" ("db.db_heap_util") breached the "upper" alarm threshold of "95 %" with value "96 %" on "database" "db2inst1.mydb ". Calculation: "((db.db_heap_cur_size/db.db_heap_max_size)*100);" = "((26673152 / 27918336) * 100)" = "96 %". History (Timestamp, Value, Formula): " (13.12.2011 19:36:15.180741, 94, ((26214400 / 27918336) * 100)), (13.12.2011 19:31:15.064721, 93, ((26017792 / 27918336) * 100)), (13.12.2011 19:26:15.908807, 93, ((26017792 / 27918336) * 100)), (13.12.2011 19:21:15.735674, 93, ((26017792 / 27918336) * 100)), (13.12.2011 19:16:15.586327, 93, ((26017792 / 27918336) * 100)), (13.12.2011 19:11:15.414727, 93, ((26017792 / 27918336) * 100)), (13.12.2011 19:06:15.278631, 93, ((26017792 / 27918336) * 100)), (13.12.2011 19:01:15.140440, 93, ((26017792 / 27918336) * 100)), (13.12.2011 18:56:15.988439, 93, ((26017792 / 27918336) * 100))" нашла на https://www-304.ibm.com/support/docview.wss?uid=swg1IC69421 Local fix •You can turn off the Monitor Alert switch by doing following: db2 update alert cfg for database manager using db2.mon_heap_util set THRESHOLDSCHECKED NO db2 update alert cfg for databases using db.db_heap_util set THRESHOLDSCHECKED NO Т.е. можно на эту ошибку не обращать внимание, а еще лучще отключить монитор? ... |
| 14.12.2011, 09:08 |
chuk_and_gek, Насколько я понял, это только если у Вас dbheap стоит в automatic... ... |
| 14.12.2011, 09:52 |
start [/forum/topic.php?desktop=1&fid=43&tid=1601990]: |
55ms |
| others: | 269ms |
| total: | 380ms |
