DB2/LUW v.10 ?
Я правильно понял из анонса, что сие как обычно "неожиданно" произошло ? В разделе DB2/LUW на портале полная тишина, зато в разделе инфосферы небольшое whats new : Effective April 30, 2012, the new InfoSphere Warehouse 10 based on DB2 10 includes a new set of advanced capabilities to enable real-time operational analytics. Заинтриговало вот это : Multi-Temperature Data Management As warehouses grow in size the storage costs also escalates. However, at the same time service level agreements for access to the warehouse are getting tighter for certain mission-critical warehouse information. Multi-temperature storage management feature allows warehouse data to be spread across multiple tiers of storage ( tiers possibly being defined by either speed of the device and/or cost of the storage ). The optimizer and workload management can then take advantage of this information about the priority and type of storage to enhance the query performance for hotter data, while at the same time lowering resources given to lower priority queries accessing archival or cold storage. Это что будет софтверный аналог стораджового Easy Tier ? Есть у кого-нибудь инфа поподробнее ? ... |
| 03.04.2012, 11:08 |
DB2/LUW v.10 ?
mitekЗаинтриговало вот это : Multi-Temperature Data Management As warehouses grow in size the storage costs also escalates. However, at the same time service level agreements for access to the warehouse are getting tighter for certain mission-critical warehouse information. Multi-temperature storage management feature allows warehouse data to be spread across multiple tiers of storage ( tiers possibly being defined by either speed of the device and/or cost of the storage ). The optimizer and workload management can then take advantage of this information about the priority and type of storage to enhance the query performance for hotter data, while at the same time lowering resources given to lower priority queries accessing archival or cold storage. Это что будет софтверный аналог стораджового Easy Tier ? Есть у кого-нибудь инфа поподробнее ? Привет. Там вводится понятие storage group, как в DB2 for Z/OS. Код: sql 1. 2. 3. 4. 5. 6. ... |
| 04.04.2012, 14:38 |
DB2/LUW v.10 ?
A matter of time: Temporal data management in DB2 10 DB2 10: What's new in DB2 10 for Linux, UNIX, and Windows ... |
| 04.04.2012, 15:47 |
DB2/LUW v.10 ?
mustaccioПрезентация онлайн - 4 апреля в 15:00. https://events.unisfair.com/index.jsp?seid=33250&eid=556 Спасибо. Было интересно. ... |
| 05.04.2012, 10:15 |
DB2/LUW v.10 ?
Mark BarinsteinПривет. Там вводится понятие storage group, как в DB2 for Z/OS. Привет, Марк. Спасибо за разъяснение. Помечталось, что это будет автоматический перенос на уровне страниц/экстентов, но так тоже неплохо :) ... |
| 05.04.2012, 10:21 |
DB2/LUW v.10 ?
mitek, Ну вот вам еще тогда :) Adaptive Compression: http://youtu.be/Zm0DYenmFvg ... |
| 05.04.2012, 18:35 |
DB2/LUW v.10 ?
PDF-ки выложили: ftp://ftp.software.ibm.com/ps/products/db2/info/vr101/pdf/en_US/ ... |
| 29.04.2012, 11:06 |
DB2/LUW v.10 ?
У external table functions всегда требовалось описывать колонки результирующей таблицы, но в 10-ке появилась generic table (только для java-функций). Но приличного описания с понятным примером я так и не нашёл. Возможно, в каталоге SAMPLE будет? ... |
| 29.04.2012, 13:22 |
DB2/LUW v.10 ?
10ка вышла GA и доступна для закачки ... |
| 30.04.2012, 12:15 |
DB2/LUW v.10 ?
О, Express-C вижу наконец (на http://www-01.ibm.com/software/data/db2/express/download.html), а прочие на http://www-01.ibm.com/software/data/db2/linux-unix-windows/download.html пока 9.7. ... |
| 30.04.2012, 16:37 |
DB2/LUW v.10 ?
Victor Metelitsaа прочие на http://www-01.ibm.com/software/data/db2/linux-unix-windows/download.html пока 9.7. ...Хотя, если пойти оттуда на https://www14.software.ibm.com/webapp/iwm/web/preLogin.do?lang=en_US&source=swg-isw97trial или https://www14.software.ibm.com/webapp/iwm/web/reg/pick.do?source=swg-dm-db297trial, всё ОК. ... |
| 30.04.2012, 16:44 |
DB2/LUW v.10 ?
Закачал Express-C... Хорошую же каку преподнесли. Традиционно я ставил DB2, распаковывая и затем запуская setup /i en. Теперь же в инсталляторе (под win x64) что-то сломали, и дальше настроек ssh-сервера он не идёт. На "непонятном языке", да, ставится, но это же потенциальное море бессмысленных проблем. Самое же ужасное - это отсутствие Control Center. И не то, что в нём было что-то хорошее, но он хоть как-то работал, а вот Data Studio пугает по-настоящему. ... |
| 01.05.2012, 09:56 |
DB2/LUW v.10 ?
Victor MetelitsaУ external table functions всегда требовалось описывать колонки результирующей таблицы, но в 10-ке появилась generic table (только для java-функций). Но приличного описания с понятным примером я так и не нашёл. Возможно, в каталоге SAMPLE будет? Using generic table functions ... |
| 01.05.2012, 11:23 |
DB2/LUW v.10 ?
Mark BarinsteinVictor MetelitsaУ external table functions всегда требовалось описывать колонки результирующей таблицы, но в 10-ке появилась generic table (только для java-функций). Но приличного описания с понятным примером я так и не нашёл. Возможно, в каталоге SAMPLE будет? Using generic table functions О, спасибо. ... |
| 01.05.2012, 13:28 |
DB2/LUW v.10 ?
"we are very pleased to announce the release of the following new best practices papers and technical papers to support the exciting new features in DB2 V10. The papers will help customers learn more about the new features, and provide them with practical recommendations to implement the features in their environments.... Best practices: Storage optimization with deep compression (Authors: Thomas Fanghaenel and Bill Minor) http://www.ibm.com/developerworks/data/bestpractices/deepcompression/index.html Best practices: A practical guide to implementing row and column access control (Author: Walid Rjaibi) http://www.ibm.com/developerworks/data/bestpractices/rcac/index.html Best Practices: Temporal data management with DB2 (Author: Matthias Nicola) http://www.ibm.com/developerworks/data/bestpractices/temporal/index.html DB2 V10.1 Multi-temperature data management recommendations (Authors: Jim Seeger, Karen McCulloch, Naresh Chainani, Kiran Chinta, Aruna De Silva, Vincent Kulandai Samy, and Tom Hart) http://www.ibm.com/developerworks/data/library/long/dm-1205multitemp/index.html DB2 V10.1 Query performance enhancements (Author: David Sky) http://www.ibm.com/developerworks/data/library/long/dm-1205db210performance/index.html ... |
| 01.05.2012, 18:45 |
DB2/LUW v.10 ?
"TOAD for DB2" заявил о поддержке LUW 10 http://dev.toadfordb2.com/releasenotes/beta/ToadDB2BetaRN.htm ... |
| 01.05.2012, 21:59 |
DB2/LUW v.10 ?
Коллеги, это всё прекрасно. А что слышно про сроки поддержки 9.Х, т.е. какое время её ещё будут поддерживать? ... |
| 02.05.2012, 09:48 |
DB2/LUW v.10 ?
Anka_SА что слышно про сроки поддержки 9.Х, т.е. какое время её ещё будут поддерживать? DB2 Distributed end of support (EOS) dates ... |
| 02.05.2012, 10:54 |
DB2/LUW v.10 ?
Удивительно (и приятно), что компрессию таблиц из Express-C пока не убрали (забыли, наверное). Насколько я вижу, как и было обещано, жать стало сильнее. В 9.1 некая базуля со сжатыми таблицами занимала > 350 гиг (это размер её несжатого бекапа), в 9.7 не особо меньше (хотя нам вроде бы и сжатие индексов обещали), а в 10.1 - база заняла на диске 260 гиг. С несжатыми таблицами займёт, наверное, 500-550 гиг (реально расжимать не пробовал). ... |
| 05.05.2012, 09:12 |
DB2/LUW v.10 ?
Victor Metelitsa В 9.1 некая базуля со сжатыми таблицами занимала > 350 гиг (это размер её несжатого бекапа), в 9.7 не особо меньше (хотя нам вроде бы и сжатие индексов обещали), а в 10.1 - база заняла на диске 260 гиг. Я долго экспериментировал со сжатием на 9.7. Если льем данные в созданную таблицу, то словарь создается неэффективный - по первой строчке, похоже. Если потом сделать реорг с перестроением словаря - ситуация резко улучшается, иногда в вдвое-втрое. Для партишион вообще самый эффективный вариант - аттачить уже правильно скомпрессированную таблицу. Для архивирования я использую следующий сценарий: create table_new_part (with compress) load into table_new_part reorg table table_new_part RESETDICTIONARY (при этом индексы тоже перестраиваются) runstats attach partition Интересно будет посмотреть на поведение 10-ки. Andy ... |
| 11.05.2012, 14:49 |
DB2/LUW v.10 ?
A.Panskikh Если льем данные в созданную таблицу, то словарь создается неэффективный - по первой строчке, похоже. В 9.7, если не ошибаюсь, ADC сэмплит первые 10МБ A.Panskikh Интересно будет посмотреть на поведение 10-ки. Как пример одной таблицы (16K pagesize) в страницах : В 10.1 Некомпресcная - 1061165 Адаптивная компрессия с реоргом - 181445 Статическая компрессия с реоргом - 241501 Адаптивная компрессия с ADC - 269336 В 9.7.5 : Статическая компрессия с ADC - 745424 Статическая компрессия с реоргом - 243110 Судя по всему ADC в 10.1 стало "более лучше" :) ... |
| 11.05.2012, 15:25 |
start [/forum/topic.php?desktop=1&fid=43&tid=1601856]: |
58ms |
76ms |
| others: | 216ms |
| total: | 401ms |
