Монитор работоспособности - состояние Недоступно.
Вот такая бяка по всем БД на сервере. DB2 v9.7.0.441, OS Win2008 Server(NT3297). В db2diag.log следующее: 2012-12-10-10.48.50.361000+240 I1105H589 LEVEL: Error PID : 3012 TID : 4400 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : TOOLSDB APPHDL : 0-45309 APPID: *LOCAL.DB2.121210064857 AUTHID : DB2ADMIN EDUID : 4400 EDUNAME: db2taskp (TOOLSDB) FUNCTION: DB2 UDB, catalog services, sqlrlCatalogScan::fetch, probe:40 RETCODE : ZRC=0x80040003=-2147221501=SQLD_INTRP "USER INTERRUPT DETECTED" DIA8003C The interrupt has been received. DATA #1 : Hex integer, 4 bytes 0x00000002 2012-12-10-10.51.58.679000+240 I1696H587 LEVEL: Error PID : 3012 TID : 3852 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : PERSDB APPHDL : 0-45383 APPID: *LOCAL.DB2.121210065217 AUTHID : DB2ADMIN EDUID : 3852 EDUNAME: db2taskp (PERSDB) FUNCTION: DB2 UDB, catalog services, sqlrlCatalogScan::fetch, probe:40 RETCODE : ZRC=0x80040003=-2147221501=SQLD_INTRP "USER INTERRUPT DETECTED" DIA8003C The interrupt has been received. DATA #1 : Hex integer, 4 bytes 0x00000002 2012-12-10-10.52.01.093000+240 I2285H587 LEVEL: Error PID : 3012 TID : 5200 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : PERSDB APPHDL : 0-45447 APPID: *LOCAL.DB2.121210065321 AUTHID : DB2ADMIN EDUID : 5200 EDUNAME: db2taskp (PERSDB) FUNCTION: DB2 UDB, catalog services, sqlrlCatalogScan::fetch, probe:40 RETCODE : ZRC=0x80040003=-2147221501=SQLD_INTRP "USER INTERRUPT DETECTED" DIA8003C The interrupt has been received. DATA #1 : Hex integer, 4 bytes 0x00000002 2012-12-10-10.52.01.385000+240 I2874H587 LEVEL: Error PID : 3012 TID : 5924 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : PERSDB APPHDL : 0-45456 APPID: *LOCAL.DB2.121210065330 AUTHID : DB2ADMIN EDUID : 5924 EDUNAME: db2taskp (PERSDB) FUNCTION: DB2 UDB, catalog services, sqlrlCatalogScan::fetch, probe:40 RETCODE : ZRC=0x80040003=-2147221501=SQLD_INTRP "USER INTERRUPT DETECTED" DIA8003C The interrupt has been received. DATA #1 : Hex integer, 4 bytes 0x00000002 Кто виноват и что делать? ... |
| 10.12.2012, 20:34 |
start [/forum/topic.php?desktop=1&fid=43&tid=1601593]: |
44ms |
28ms |
| others: | 257ms |
| total: | 370ms |
