powered by simpleCommunicator - 2.0.60     © 2026 Programmizd 02
Форумы / IBM DB2, WebSphere, IMS, U2 [игнор отключен] [закрыт для гостей] / restore+rebuild+redirect=SQL0752N
    #38170084
m7272
ese9.5 aix5.3
Не могу сделать восстановление существующей базы в новую (несуществующую) базу нужных tablespaces с redirect.
Код: sql
1.
2.
3.
RESTORE DATABASE olddb REBUILD WITH TABLESPACE () ... INTO newdb REDIRECT;
SET TABLESPACE CONTAINERS FOR;
после
Код: sql
1.
RESTORE DATABASE olddb CONTINUE;
выдает:
Код: sql
1.
2.
3.
4.
SQL1277W  A redirected restore operation is being performed.  Table space
configuration can now be viewed and table spaces that do not use automatic
storage can have their containers reconfigured.
DB20000I  The RESTORE DATABASE command completed successfully.
но дальше:
Код: sql
1.
2.
3.
rollforward db newdb to end of logs and complete
SQL0752N  Connecting to a database is not permitted within a logical unit of
work when the CONNECT type 1 setting is in use.  SQLSTATE=0A001
Бэкап валидный. Восстановление полной базы с редиректом и накатом транзакций проходит.
diag (level 3):
2013-02-28-22.29.12.551437+480 E36021227A1068 LEVEL: Warning
PID : 266268 TID : 16180 PROC : db2sysc 0
INSTANCE: inst NODE : 000 DB : OLDDB
APPHDL : 0-28245 APPID: *LOCAL.inst.130228142914
AUTHID : INST
EDUID : 16180 EDUNAME: db2agent (OLDDB) 0
FUNCTION: DB2 UDB, database utilities, sqludCheckRedirectedStatus, probe:1019
MESSAGE : SQL1277W A redirected restore operation is being performed. Table
space configuration can now be viewed and table spaces that do not
use automatic storage can have their containers reconfigured.
DATA #1 : SQLCA, PD_DB2_TYPE_SQLCA, 136 bytes
sqlcaid : SQLCA sqlcabc: 136 sqlcode: 1277 sqlerrml: 0
sqlerrmc:
sqlerrp : sqludChe
sqlerrd : (1) 0x00000000 (2) 0x00000000 (3) 0x00000000
(4) 0x00000000 (5) 0x00000000 (6) 0x00000000
sqlwarn : (1) (2) (3) (4) (5) (6)
(7) (8) (9) (10) (11)
sqlstate:
2013-02-28-22.29.12.555265+480 I36022296A320 LEVEL: Severe
PID : 586390 TID : 1 PROC : db2bp
APPID : *LOCAL.inst.130228142914
EDUID : 1
FUNCTION: DB2 UDB, base sys utilities, sqleStartUsingDatabase, probe:2
RETCODE : ZRC=0xFFFFFD10=-752
2013-02-28-22.29.12.555843+480 I36022617A351 LEVEL: Error
EDUID : 1
FUNCTION: DB2 UDB, data protection services, sqlpsrllf, probe:317
MESSAGE : Rollforward failed to connect to database. sqlcode -752.
Кто как делал подобный restore + rebuild + redirect?
